Patriot 16GB USB 3.0 Drive - corrupt and Read Only {solved}
patriot 16gb usb drive flash
4 replies to this topic
#1 OFFLINE   LilBambi
LilBambi
    Australisches Googler
  • 22,548 posts
Posted 22 June 2014 - 04:22 PM
I have a wonderful Patriot 16GB USB 3.0 drive that suddenly decided to puke on me.
It was not working right on any type of computer; corrupted data and read only. You could see nothing even if it was viewable. And you couldn't even reformat it because EVERYTHING including Linux thought it was read only.
I did some searching around and the first result in a Google search had the answer:
Patriot Axle 16gb, "write protected" "corrupt"
In that topic on the Patriot Forums, this is the thing that worked for me:
Can you please see if our low level format/reset tool will restore the drive for normal use? Please give it a try. Please note that the formatter must be done on a PC. You can extract it to the desktop and run it from there.
Here is the link to the formatter:
http://www.patriotme....re/Restore.rar
Thanks you Patriot Forums' Patriot_Ben! Would have hated to lose that wonderful 16GB Drive!
So far so good. I have reformatted it three times and am in the process of copying all the stuff I had on it before.
I just hope it does not mean that the chip is starting to fail....
Edited by LilBambi, 22 June 2014 - 04:24 PM.
Bambi
AKA Fran
#2 OFFLINE   Capt.Crow
Capt.Crow
    Multithreader
  • PipPipPipPipPipPipPipPip
  • 1,237 posts
Posted 22 June 2014 - 04:52 PM
Same thing happened with a  16$ 64gb Intenso . usb drive . The distributor got so many of them back they discontinued the line.
I was stumped . so brought it to the Nephew . He d/loaded the kicker and installed it write protect. From his PC. Its perfect now filled and emptied with lotsa movies  regularly. . But **no format*
no way . Just delete files only ==/dev/null.
Linux counter no . 393441
#3 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,704 posts
Posted 22 June 2014 - 05:20 PM
Wow! You got lucky, Fran! :)
Remember folks, nothing is forever.
https://en.wikipedia...Write_endurance
#4 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 22 June 2014 - 07:48 PM
If I can't format it safely, it's of no use to me. I had to test it with format. I use this on other people's computers and you just never know when you will need to use Linux to remove the partition and reformat it.
I don't use it on known bad computers, but there are some where I didn't realize they had a problem and before i use it anywhere else, it's wiped in Linux ... partition and formatting.
Haven't had to do it very often but you just never know...
I usually use CDs and DVDs to work on sick computers though.
Bambi
AKA Fran
#5 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 22 June 2014 - 07:50 PM
So glad others have found these low level formatters work for them too.
What make was yours Capt.Crow, Intenso? Never heard of it. But I also got a general formatter that can be used for others from that forum topic as well.
Bambi
AKA Fran
Also tagged with one or more of these keywords: patriot, 16gb, usb, drive, flash
