Touch Pad Will Not Scroll
touch pad scroll hp notebook
17 replies to this topic
#1 OFFLINE   Purhonen
Purhonen
    Post Master
  • PipPipPipPip
  • 122 posts
Posted 18 January 2013 - 08:45 PM
My Synaptic touch pad will not scroll.
HP G60T-200 notebook, Win 7 (32 bit)
Device Manager says device working properly.  Tried updating drivers - response was latest drivers installed.  Visited HP site to check on drivers for the touch pad - latest version listed for download was same as what Device Manager listed.
When I attempt to scroll the scroll icon (small scroll bar appears under cursor/pointer) appears but no vertical movement.
Tried resetting the device, no change.
Should I reinstall the device?  If so, how do I do it?  Simply uninstall the driver and reinstall?
Steve
#2 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,504 posts
Posted 18 January 2013 - 10:09 PM
Hi, Purhonen!
Stand by... Adam or one of the other gadget experts will be along shortly to give you a hand with this issue you're experiencing. It's not my forte. Sorry.
#3 OFFLINE   ross549
ross549
    I live here.
  • 9,185 posts
Posted 18 January 2013 - 10:19 PM
This really sounds like the driver settings are not correct. Do you have a Synaptics control panel applet? Scrolling should be able to be enabled/disabled from the applet.
Adam
#4 OFFLINE   goretsky
goretsky
    Posting Prodigy
  • 2,006 posts
Posted 19 January 2013 - 03:36 AM
Hello,
The latest version of the touch pad driver offered by Hewlett Packard is Synaptics PS/2 Port Touchpad 13.2.2.0 A.  If reinstalling this does not solve the problem, perhaps a newer version will help.
A quick check of Synaptics web site reveals a newer version of the drive: Synaptics Touch Pad Device Driver v16.2.21 C.
Regards,
Aryeh Goretsky
Dexter is a good dog.
Aryeh Goretsky
#5 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,504 posts
Posted 19 January 2013 - 02:08 PM
Thanks guys for responding. I was the only one online yesterday when Steve posted this. I'm definitely not qualified to help with this issue. ;)
#6 OFFLINE   Purhonen
Purhonen
    Post Master
  • PipPipPipPip
  • 122 posts
Posted 19 January 2013 - 07:50 PM
Adam
Adam,
Thanks for your response.  Yes, I do have the Synaptics control panel, and yes, I have enabled the scrolling (both vertical and horizontal) . . . still no change.
#7 OFFLINE   Purhonen
Purhonen
    Post Master
  • PipPipPipPip
  • 122 posts
Posted 19 January 2013 - 08:09 PM
View Postgoretsky, on 19 January 2013 - 03:36 AM, said:
Hello,
Regards,
Aryeh Goretsky
Aryeh,
Thanks for the info. I found the same driver version at the HP site that you listed, that is also the driver version listed for the Synaptic touchpad in the Device Manager.  So I don't think that is the source of the problem.
How about I try uninstalling and reinstalling the Synaptics PS/2 Port Touchpad 13.2.2.0 A drivers.  If nothing changes I will then try installing the later version of the drivers you so kindly linked.  Does that sound like a plan?
If this is a good approach, I would appreciate any tips/things to be careful about when uninstalling/reinstalling device drivers in general.
Thanks, Steve
#8 OFFLINE   LilBambi
LilBambi
    Australisches Googler
  • 22,545 posts
Posted 20 January 2013 - 10:45 AM
Hey Steve,
Yes, that does sound like the next diagnostic step.
I would uninstalled the software; reboot, then install the new software.
Hope it's not a hardware issue - defective.
Bambi
AKA Fran
#9 OFFLINE   ross549
ross549
    I live here.
  • 9,185 posts
Posted 20 January 2013 - 10:59 AM
If the touchpad works other than just not scrolling, then I highly doubt the device is defective. I suspect a registry bit got flipped somehow, and the control panel applet cannot make the proper changes any more.
If the updated driver does not work, a precision strike of removing the registry keys and such may be required to restore functionality.
Adam
#10 OFFLINE   LilBambi
LilBambi
  • 22,545 posts
Posted 20 January 2013 - 11:16 AM
Interesting. There are a bunch of folks that have had this scrolling problem.
There was one guy who had the problem as well, and looked at the hardware info in Control Panel/Hardware for his Touchpad, and it was an ALPs one. He downloaded and installed the ALPs driver instead of Synaptic, and it started working.
It also worked for a guy he mentioned it to.
See info posted by ymo as the suggested answer here: Touchpad scroll does not work - what to do? - Dell Inspiron 6000d
If it turns out that you do have an ALPS Touchpad...
Drivers for ALPS Touchpad:
Dell ALPS Touchpad
Or since you have an HP Steve, you could instead try the HP one: Alps Touchpad Driver
Edited by LilBambi, 20 January 2013 - 11:17 AM.
Bambi
AKA Fran
#11 OFFLINE   zlim
zlim
    It's me, plodr
  • 7,141 posts
Posted 20 January 2013 - 12:20 PM
Download Speccy http://www.filehippo...search?q=Speccy
and check under either motherboard or peripherals to see the touchpad hardware. I'm on a desktop so I don't know the category touchpad would be located.
Warning: Watch carefully as you run the exe for speccy. It will want to install Google chrome and make it the default browser.
I unchecked make chrome the default first, then unchecked install chrome.
Liz
#12 OFFLINE   crp
crp
  • 3,108 posts
Posted 20 January 2013 - 04:28 PM
If you are still having problems with the scrolling ...
since it is Win7, i would uninstall the driver for the scroller and then cold reboot.
If Win7 sees the scroller it will prompt you for the next action. If it doesn't , well then I think you would have the problem possibilities narrowed down .
#13 OFFLINE   Purhonen
Purhonen
    Post Master
  • PipPipPipPip
  • 122 posts
Posted 20 January 2013 - 08:38 PM
Thank you all for your help - you're a great gang!
I cold-booted last night and everything is back to normal, scroll and all.  (I never did uninstall or reinstall any device drivers)
I apologize for not trying a cold boot before I posted -- I should have.  I've fallen into the habit of hibernating my laptop for days at a time, maybe I should keep my hibernations to just a couple of days at a time?
Thanks Again, Steve
#14 OFFLINE   crp
crp
  • 3,108 posts
Posted 20 January 2013 - 09:02 PM
ahh, so not everything woke up. wonder if a logoff/logon would have done the trick. try that if it happens again.
#15 OFFLINE   LilBambi
LilBambi
  • 22,545 posts
Posted 21 January 2013 - 03:30 PM
Ah, yes. Cold boots are a good thing! :D :thumbsup:
Glad that is all it was.
Bambi
AKA Fran
#16 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,543 posts
Posted 25 January 2013 - 03:13 PM
i hate hibernation for that and other reasons.
but am glad your scrolling is back!
#17 OFFLINE   LilBambi
LilBambi
  • 22,545 posts
Posted 25 January 2013 - 09:26 PM
Yes, hibernation is often not worth it. Can drop things like that or network connections, or just get wonky.
Works fine until it fails gloriously.
Edited by LilBambi, 25 January 2013 - 09:47 PM.
Bambi
AKA Fran
#18 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,543 posts
Posted 27 January 2013 - 04:13 AM
View PostLilBambi, on 25 January 2013 - 09:26 PM, said:
,,,Works fine until it fails gloriously.
lol - love it!
Also tagged with one or more of these keywords: touch pad, scroll, hp notebook
