Setup freezes !!!
7 replies to this topic
#1 OFFLINE   reza
reza
    Contributor
  • PipPip
  • 24 posts
Posted 27 August 2004 - 01:05 PM
In fact, this is my colleague problem. One day he brought his case to me an said me to change the Windows 2000. :w00t:  Because the Windows had many problems, I decided to format the partition and reinstall Windows. :w00tx100:  Every thing went well, but when the setup was installing the components, it did not go forward and freezed. I changed the installation CD but again that problem accured. So I decided to install Win XP, but again when the setup was installing the devices that problem accured. Please help me. Thanx.  :'(
#2 OFFLINE   epp_b
epp_b
  • 4,735 posts
Posted 27 August 2004 - 01:20 PM
Hmmm...interestingly enough, I had a similar problem with Windows 98 and XP setups freezing on me.  What are the specs on this machine? (CPU, RAM, HDD capacity, etc.).I might be able to actually get inside that PC today - I'll let you know if I fix the problem :w00tx100:
#3 OFFLINE   reza
reza
    Contributor
  • PipPip
  • 24 posts
Posted 27 August 2004 - 01:23 PM
OkCPU: Pentium IIIRAM: 64Hard: 40and Thanx
#4 OFFLINE   mtbparker
mtbparker
    Message Adept
  • PipPipPip
  • 47 posts
Posted 27 August 2004 - 02:34 PM
I had similar problem when I upgraded my Windows 98 box to Windows XP.  My problem was that I had an incompatible PCI modem installed.  The real problem wasn't that the modem wasn't recognized by XP, it was that XP installation gave absolutely NO indication what was wrong -- it just froze.It was only after I re-formatted my hard-disk and attempted to reinstall 98 using my recovery disks that I figured it out.  It too had problems with the modem, but this time it let me know.  I had to pull the modem out to get the install to work.The original modem that came with the computer had died and I had installed a Hayes modem.  Being that it was 2 years later and I had upgraded to a DSL/ethernet connection, I had completely forgotten about this modem.Check if he's got hardware in there that XP doesn't recognize.  Back during the release of XP, there were a lot of tables on the internet listing incompatible devices.  Maybe you can compare one of those tables to the hardware inside the box.
#5 OFFLINE   James M. Fisher
James M. Fisher
    Minimally Valuable Poser
  • 2,723 posts
Posted 27 August 2004 - 04:15 PM
Usually install problems can be traced to a hardware conflict of some sort and stripping out as much hardware as possible to get Windows installed often solves the problem.
James M. Fisher
#6 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
My recommendation is to pull any PCI cards that aren't absolutely necessary.  You don't need network/modem/sound to do the install, so remove the cards for the install, and then reinstall them when you're done.  I have to do this with my NIC every time i do a fresh install.BTW... XP isn't going to run well (if at all) on that machine...  there's nowhere near enough RAM
#7 OFFLINE   Ozidave
Ozidave
    Multithreader
  • 1,446 posts
Posted 27 August 2004 - 04:48 PM
reza, on Aug 28 2004, 02:51 AM, said:
RAM: 64
XP recommendation is 132Mb RAM minimum. :thumbsup:
#8 OFFLINE   epp_b
epp_b
  • 4,735 posts
Awk!  I'm not at all surpirsed that WinXP didn't install.  That machine is far too old to run WinXP properly.  At the very least, the RAM will need to be upgraded to 256 MB.Anyway, about that machine I was having problems with.  The hard drive was the culprit.  I replaced it, and Win98 installed very nicely.
