bjf123 Posted April 22, 2004 Share Posted April 22, 2004 I've got a Linksys BEFW11S4 router that I use to share my DSL connection between two hardwired systems, one dual booting between Win98 and SuSE 8.2 and a iMac running OS X. I also have a Mac iBook connecting wirelessly. I'm currently using the default settings of the Linksys handling DHCP, but limited to only allowing 3 connections. The router has the default 192.168.1.1, with the three PCs starting elsewhere. I'm thinking I want to turn off DHCP and assign static IPs to the three systems. First, would that be any more secure, since the router wouldn't be handing out IPs? Is there any more security in changing the router's IP to something like 192.168.8.3? If I do turn off DHCP, is there a way in the router to only allow the three specified IPs? I've looked, but haven't come across any way to do that, other than letting the router handle DHCP and telling it what IP to use as the starting point. Quote Link to comment Share on other sites More sharing options...
nlinecomputers Posted April 22, 2004 Share Posted April 22, 2004 Why not set the restrict you router by MAC address. That would limit you to the hardware that you have currently connected. Most secure method for restricting access.The only real way I can think of to restrict IP addresses would be by a subset mask. Quote Link to comment Share on other sites More sharing options...
JackR Posted April 22, 2004 Share Posted April 22, 2004 The vulnerable part is the Wireless.To protect your self from casual Wireless "leaching" by a neighbor you can use MAC filter.All the playing with DHCP will not protect you from a deliberate sniffer, since he will sniff what ever IP is used.Link: Wireless Security. Quote Link to comment Share on other sites More sharing options...
bjf123 Posted April 22, 2004 Author Share Posted April 22, 2004 Why not set the restrict you router by MAC address. That would limit you to the hardware that you have currently connected. Most secure method for restricting access.I did that for the laptop that connects wirelessly when I set up the router. I didn't think to do it for the two hard wired systems. Thanks! I've got both WEP and WPA capabilities, but have a few quirks in trying to get either to work consistently. Quote Link to comment Share on other sites More sharing options...
bjf123 Posted April 23, 2004 Author Share Posted April 23, 2004 Why not set the restrict you router by MAC address. That would limit you to the hardware that you have currently connected. Most secure method for restricting access.I did that for the laptop that connects wirelessly when I set up the router. I didn't think to do it for the two hard wired systems.Turns out there's nowhere in the Linky setup to filter for wired MAC addresses, only wireless. Quote Link to comment Share on other sites More sharing options...
JackR Posted April 23, 2004 Share Posted April 23, 2004 Wireless security and Wired security are Not an equal. Unless you have an RJ-45 port available to the public to Plug In you Do Not need MAC filtering for the Wired part.Link to: Basic Protection for Broadband Internet Installation.Link to: Wireless Security.As see two independent links for Wire and Wireless. Quote Link to comment Share on other sites More sharing options...
