Trouble using the iTunes Music Store
Lover of quiet computers
I'm using iTunes on Windows XP Home Edition. When I click the buttons to add songs to the shopping cart, I understand I'm supposed to click a link to the cart in the Source column. My problem is, such an item (for the shopping cart) never appears. Is it possible I deleted the link by mistake in the past?
No mater what OS you are using with iTunes: Mac or Windows XP, you need to enable the shopping cart, for the iTunes Music Store.Mac OS X : iTunes > Preferences > Store > Buy using Shopping CartWindows : iTunes > Edit > Preferences > Store > Buy using Shopping CartOnce enabled, the shopping cart will appear in the left “source†pane as it’s own line item.
I got the problem resolved. I always did have the shopping cart enabled; I just didn't know I was supposed to click on the little triangle in the Source pane to show it! :D
