HDMI powered portable monitors.
7 replies to this topic
#1 OFFLINE   lewmur
lewmur
  • 3,604 posts
Posted 29 April 2016 - 01:01 PM
Where are they???? :angry2: :angry2:   Ever since the advent of small board PCs like the Pi and small Android tablets, I've been waiting for someone to come up with an HDMI powered portable monitor.  Something in the 14" range or above.  There are now USB monitors in that range, but they are only for Windows boxes.
#2 OFFLINE   LilBambi
LilBambi
    Australisches Googler
  • 22,509 posts
Posted 02 May 2016 - 07:19 PM
There are converters for vga and/or hdmi/dvi to USB that might work for that. I just got one for an older Mac that has a bad video card and I need to get the data from the drive. I hope it will work. Not sure yet. It has only Windows drivers, but sometimes Macs just work for stuff, so gonna try it and see.
Bambi
AKA Fran
#3 OFFLINE   crp
crp
    Board Bigwig
  • 2,985 posts
Posted 03 May 2016 - 03:27 AM
The portable USB monitors are okay when you really need something bigger than your portable device screen but that is about it. Response time is noticeably slower and resolution limited to 1368*720. And the power drain is quite a bit.
If your device has USB3, the USB->HDMI adapters may do for you but they do not provide power.
#4 OFFLINE   lewmur
lewmur
  • 3,604 posts
Posted 03 May 2016 - 10:10 AM
As I said in the OP,  USB monitors don't work with Linux developer boards like the Pi or Odroid nor do they work with Android tablets.  Useless for my purposes.  I'm not worried about the power supply.  High capacity battery packs are getting cheaper all the time.  I carry several with me just as a matter of course.
Edited by lewmur, 03 May 2016 - 10:14 AM.
#5 OFFLINE   goretsky
goretsky
    Forum Fiend
  • 1,880 posts
Posted 05 May 2016 - 03:37 AM
Hello,
The HDMI spec only delivers +5VDC, 0.055A (55mA), compared to 0.5A (500mA) for USB 2.0 / 0.9A (900mA) for USB 3.0, so I wouldn't expect to see any kind of device powered by HDMI unless it was something like Bluetooth Low Energy or ZigBee for IoT applications.
On the other hand, the MHL interface allows USB-levels of power, and the superMHL specification (ratified in January 2016), supports 40W of power delivery for charging.  I'm not sure if that would work going from the display source to the external monitor, though.
Regards,
Aryeh Goretsky
Dexter is a good dog.
Aryeh Goretsky
Microsoft MVP (Windows - IT Pro)
Facebook Google+ personal blog personal website Twitter
#6 OFFLINE   abarbarian
  • 5,100 posts
Posted 06 May 2016 - 07:24 PM
Answer = Amazon
http://www.amazon.co...s/dp/B00H4MWMWQ
http://www.gechic.co...elp_en.asp?s=14
:breakfast:
My answer is not 100% correct but I guess the Gechic would satisfy your needs.
https://www.raspberr...hp?f=38&t=81366
Edited by abarbarian, 06 May 2016 - 07:35 PM.
Install ARCH
"I did and I'm really happy"
#7 OFFLINE   lewmur
lewmur
  • 3,604 posts
Posted 07 May 2016 - 09:53 AM
Answer = Amazon
:breakfast:
Yeah.  It would satisfy my needs.  Just not my pocketbook!! :clap:
#8 OFFLINE   lewmur
lewmur
  • 3,604 posts
Posted 23 June 2016 - 01:41 PM
Turns out there is an app called DisplayLink in Android (and supposedly in Linux) that allows you to mirror the display on a USB monitor.  You can't "extend" the display like it does in Windows, but you can mirror a small phone or tablet display to a larger monitor.  I was able to buy a 15.6" USB monitor for about $60.  The only problem is that if your device only has the micro USB connector, you can't charge and use the monitor at the same time.  But you can, however, power the monitor itself from a charger or battery pack so that it doesn't take power from your device.
