Capt.Crow Posted May 6, 2014 Share Posted May 6, 2014 Badly stuck on howto install above model on Deb. So far I have been using Mega Camera Manager on XP pro. But the transfer leaves the photos blurred (lossy) I would really appreciate pointers so I could upload direct to debian hd and work with KDE Xcam. I love this little camera even if it is a low pixel steam age model . It is tiny and very efficient. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 6, 2014 Share Posted May 6, 2014 (edited) Hi Capt Crow. You want to use the current Stable Wheezy, not Squeeze. Might even be supported out of the box. libphoto2-2 might help since it is the lib from libgphoto2-2, Kamera, etc. in current stable Wheezy for libphoto2-2 Here's more info on gPhoto Project that provides that libgphoto and lists yours as well as other cameras as supported for gphoto. I would try to update your repos and then try to install libgphoto2-2 on your Squeeze install and see if it's available. I have the current libgphoto2-2 on my Debian Wheezy install in KDE via Kamera. Edited May 6, 2014 by LilBambi Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted May 6, 2014 Author Share Posted May 6, 2014 Thats awesome I've spent weeks mooching around for anything near that .. Many thanks .will let you know how I get on . 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 7, 2014 Share Posted May 7, 2014 Keeping fingers crossed! If it doesn't work in Squeeze, you might want to redo your install up to Wheezy. Here's hoping it will work for you though. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 7, 2014 Share Posted May 7, 2014 Also, shouldn't this be posted in BATL instead of Hardware? Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 7, 2014 Share Posted May 7, 2014 Could go either way actually since the question is about Capt. Crow's Camera support in Linux. We can move it there and leave a link here. That way people will see it in both but it will be in BATL. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 7, 2014 Share Posted May 7, 2014 Sounds good to me Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 7, 2014 Share Posted May 7, 2014 http://www.damonlynch.net/rapid/features.html Import your photos and videos efficiently and reliably Rapid Photo Downloader for Linux is written by a photographer for professional and amateur photographers. Its goal is to be the best photo and video downloader for the Linux Desktop. It is free software, released under the GNU GPL license. Main features 1Generates meaningful, user configurable file and folder names 2Downloads photos and videos from multiple devices simultaneously 3Backs up photos and videos as they are downloaded 4Is carefully optimized to download and back up at high speed 5Easy to configure and use 6Runs under Gnome, KDE and other Linux desktop environments 7Available in thirty languages 8Program configuration and use is fully documented I used this with my Cannon Powershot on Arch 64. Worked very well. Not sure if this is the sort of program you are after. 2 Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 7, 2014 Share Posted May 7, 2014 libgphoto2-2 is in the squeeze repo. 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 7, 2014 Share Posted May 7, 2014 Thanks sunrat! Excellent! Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted May 9, 2014 Author Share Posted May 9, 2014 gphoto2 .2.4.5-3...command line client This I installed .now I gotta find the man page gphotofs 0.4.0-3 filesystem to mount cams This one umm! I have in Info centre uchi hst ctlr 2 :- SPCA504a Digital Camera. Well at least the puter knows the cam is there. So I ran a camera search on synaptic and came uo with some interesting files.to witt eject 2.1.5 Some of these look usefull exiv2 0.2.0-2 There was the "sane" suite too halinfo 20091131-1 stuff for scanner. Later much later for that. libcv2.1 2.1.9-3 libcvaux2.1 2.1.0-3 libdc 1394-22 2.1.0-3 libexif12 0.6.19-1 Ouch that post did not upload the way I blocked it out Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 10, 2014 Share Posted May 10, 2014 I would try to install Kamera (from KDE) works great and makes use of your gphoto2-2. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 10, 2014 Share Posted May 10, 2014 Debian Rapid Photo Downloader is packaged in Debian unstable and Debian experimental. http://www.damonlynch.net/rapid/download.html I installed this on Arch yesterday, took two minutes. took another couple of minutes to set up. Works well. Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted May 10, 2014 Author Share Posted May 10, 2014 I had a good read www.damonlync Its a little too far out there for me. Looks like something for the professionals. I am going to try Kamera. As soon as I find a way to unload all the junk that is threatening the kernel . I really should have completed the Slackbox before I started messing about with this one . Fingers crossed 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 11, 2014 Share Posted May 11, 2014 Always good to not paint yourself into a corner ... then kernel panic doesn't panic user as much. Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted June 7, 2016 Author Share Posted June 7, 2016 This thorny old problem has raised it's ugly head again. I took some photos of a friends farm the other day .I would really like to 1 see them 2 print them out 3 do a painting of the best one . Kamera installed lsusb :- bus 003 device 003:id 04fc; 504a Sunplus Technology Co.,Ltd Aipteck Mini PenCam 1.3 So it's there ,it's live . Just cant mount it . Not even get the EXE to kick with Wine . on Deb 8 Will not even work on W7 although someone else was trying that out (synaptic:1686): GLib-CRITICAL **: g_child_watch_add_full: assertion 'pid > 0' failed The gtk frontend needs a working python-gtk2 and python-glade2. Those imports can not be found. Falling back to pager. The error is: No module named glade Selecting previously unselected package gphotofs. (Reading database ... 118121 files and directories currently installed.) Preparing to unpack .../gphotofs_0.5-2_i386.deb ... Unpacking gphotofs (0.5-2) ... Selecting previously unselected package libc-dev-bin. Preparing to unpack .../libc-dev-bin_2.19-18+deb8u4_i386.deb ... Unpacking libc-dev-bin (2.19-18+deb8u4) ... Selecting previously unselected package libc6-dev:i386. Preparing to unpack .../libc6-dev_2.19-18+deb8u4_i386.deb ... Unpacking libc6-dev:i386 (2.19-18+deb8u4) ... Selecting previously unselected package libexif-dev. Preparing to unpack .../libexif-dev_0.6.21-2_i386.deb ... Unpacking libexif-dev (0.6.21-2) ... Selecting previously unselected package pkg-config. Preparing to unpack .../pkg-config_0.28-1_i386.deb ... Unpacking pkg-config (0.28-1) ... Selecting previously unselected package libgphoto2-dev. Preparing to unpack .../libgphoto2-dev_2.5.4-1.1+b2_i386.deb ... Unpacking libgphoto2-dev (2.5.4-1.1+b2) ... Selecting previously unselected package libgphoto2-dev-doc. Preparing to unpack .../libgphoto2-dev-doc_2.5.4-1.1_all.deb ... Unpacking libgphoto2-dev-doc (2.5.4-1.1) ... Selecting previously unselected package manpages-dev. Preparing to unpack .../manpages-dev_3.74-1_all.deb ... Unpacking manpages-dev (3.74-1) ... Selecting previously unselected package python-piggyphoto. Preparing to unpack .../python-piggyphoto_0.1dev-git20141014_all.deb ... Unpacking python-piggyphoto (0.1dev-git20141014) ... Selecting previously unselected package libgphoto2-2-dev. Preparing to unpack .../libgphoto2-2-dev_2.5.4-1.1+b2_i386.deb ... Unpacking libgphoto2-2-dev (2.5.4-1.1+b2) ... Processing triggers for man-db (2.7.0.2-5) ... Setting up libgphoto2-dev-doc (2.5.4-1.1) ... Setting up gphotofs (0.5-2) ... Setting up pkg-config (0.28-1) ... Setting up python-piggyphoto (0.1dev-git20141014) ... Setting up libc-dev-bin (2.19-18+deb8u4) ... Setting up manpages-dev (3.74-1) ... dpkg: dependency problems prevent configuration of libc6-dev:i386: libc6-dev:i386 depends on linux-libc-dev; however: Package linux-libc-dev is not installed. dpkg: error processing package libc6-dev:i386 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libexif-dev: libexif-dev depends on libc6-dev; however: Package libc6-dev:i386 is not configured yet. dpkg: error processing package libexif-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libgphoto2-dev: libgphoto2-dev depends on libexif-dev; however: Package libexif-dev is not configured yet. dpkg: error processing package libgphoto2-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libgphoto2-2-dev: libgphoto2-2-dev depends on libgphoto2-dev (= 2.5.4-1.1+b2); however: Package libgphoto2-dev is not configured yet. dpkg: error processing package libgphoto2-2-dev (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: libc6-dev:i386 libexif-dev libgphoto2-dev libgphoto2-2-dev W: Failed to fetch http://ftp.de.debian.org/debian/pool/main/l/linux/linux-libc-dev_3.16.7-ckt25-1_i386.deb 404 Not Found E: Sub-process /usr/bin/dpkg returned an error code (1) A package failed to install. Trying to recover: dpkg: dependency problems prevent configuration of libc6-dev:i386: libc6-dev:i386 depends on linux-libc-dev; however: Package linux-libc-dev is not installed. dpkg: error processing package libc6-dev:i386 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libexif-dev: libexif-dev depends on libc6-dev; however: Package libc6-dev:i386 is not configured yet. dpkg: error processing package libexif-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libgphoto2-dev: libgphoto2-dev depends on libexif-dev; however: Package libexif-dev is not configured yet. dpkg: error processing package libgphoto2-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libgphoto2-2-dev: libgphoto2-2-dev depends on libgphoto2-dev (= 2.5.4-1.1+b2); however: Package libgphoto2-dev is not configured yet. dpkg: error processing package libgphoto2-2-dev (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: libc6-dev:i386 libexif-dev libgphoto2-dev libgphoto2-2-dev Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 8, 2016 Share Posted June 8, 2016 Looks like it's stopping because The gtk frontend needs a working python-gtk2 and python-glade2.Package linux-libc-dev is not installed. Try installing those first. Quote Link to comment Share on other sites More sharing options...
Dr. J Posted June 8, 2016 Share Posted June 8, 2016 What it looks like to me is it simply can't find the correct version of one of the dependencies... This happened to me a few times because I didn't refresh the package database before installing something. Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 8, 2016 Share Posted June 8, 2016 Oops, I missed that this was on Debian Squeeze. LTS ended back in February. You can still use it but you need to change to the to the archive repositories. Better would be to upgrade to Debian Jessie, or even Wheezy which will have LTS until 2018. There are no security updates for Squeeze any more. Update to Wheezy - https://wiki.debian.org/LTS/Using Change to Squeeze archive - https://wiki.debian.org/DebianSqueeze Q) Now that squeeze is archived, how do I get packages for it? Use the following in your sources.list: deb http://archive.debian.org/debian squeeze maindeb http://archive.debian.org/debian squeeze-lts main The second line will fail with an "expired" type message, so you also need to add the following in /etc/apt/apt.conf (create it if it doesn't already exist): Acquire::Check-Valid-Until false; Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted June 8, 2016 Author Share Posted June 8, 2016 Thanks for the reply Sunrat . The squeese is squashed and now it's moved on to Jessie . Deb 8 . What I don't understand is why the python -gtk2 and python-glade2 are not coming down from the repos. Synaptic giving a 404 on these Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 9, 2016 Share Posted June 9, 2016 Do apt-cache policy python-gtk2 python-glade2 They are definitely in the Jessie repo. Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted June 9, 2016 Author Share Posted June 9, 2016 Yes they are listed in the Synaptic . Just not installed . and don,t come down the line . Tried twice . .Will do an SU and apt-get . .......... Just did apt-cache and yes thet are both installed 2.24.0-4 . Aghhhhh! where is the gui for the camera.. Head banger for sure . Any more of this and it's back to Slack for me . Quote Link to comment Share on other sites More sharing options...
securitybreach Posted June 9, 2016 Share Posted June 9, 2016 Odd for sure Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 10, 2016 Share Posted June 10, 2016 Please do as root from a terminal - apt-get update then apt-get install -f It's trying to download linux-libc-dev_3.16.7-ckt25-1 while the current version on the server is linux-libc-dev_3.16.7-ckt25-2 . Which means you probably didn't update the package database before trying to install. Hopefully the 2 commands above will fix it. Synaptic should have worked as long as you did Refresh before trying to install. I don't trust it to recover problems as well as apt-get which is why the second command may be better than Synaptic. 1 Quote Link to comment Share on other sites More sharing options...
Dr. J Posted June 10, 2016 Share Posted June 10, 2016 Here's an interesting one... I came across (or rather, found after some time searching) a medion camera I have. The md5319, same as yours Captain! Anyway, I tried it on Arch but got nothing (It was there, lsusb found it, but no mountable filesystems), so I tried it on my backup netbook, also on Debian 8 with the MATE desktop. Soon as I plugged it in, there it was on the desktop! I installed Kamera, but honestly I don't think I needed it... Double click on the icon and up it pops, even had a few old photos on it. I've got a funny feeling that (rock solid as it may be) Debian offers vastly different configs with different desktop environments. Might be a bit extreme, but installing MATE might pull down the libs required to mount your camera. 1 Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 10, 2016 Share Posted June 10, 2016 @Dr.J what does lsusb say your camera model is? gphoto2 lists Medion MD 5319 as supported - http://www.gphoto.or...to2/support.php If the camera supports MTP or PTP it should not even need libgphoto2. More weirdness, libgphoto2 does not even list the dev packages as dependencies. Quote Link to comment Share on other sites More sharing options...
Dr. J Posted June 11, 2016 Share Posted June 11, 2016 Here it is... Bus 003 Device 006: ID 04fc:504a Sunplus Technology Co., Ltd Aiptek Mini PenCam 1.3 I've installed MATE on Arch as well now (I actually prefer it over KDE, and plasma 5 will eventually do an annoying, buggy upgrade to version 6) and whatever the kicker is, it's not part of that. I installed libgphoto2, but that didn't make it kick in automatically anyway. Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 12, 2016 Share Posted June 12, 2016 Here it is... Bus 003 Device 006: ID 04fc:504a Sunplus Technology Co., Ltd Aiptek Mini PenCam 1.3 Definitely the same as Capt.Crow's. I've installed MATE on Arch as well now (I actually prefer it over KDE, and plasma 5 will eventually do an annoying, buggy upgrade to version 6) and whatever the kicker is, it's not part of that. I installed libgphoto2, but that didn't make it kick in automatically anyway. I don't imagine DE has much to do with it.I love Plasma 5 but it is still a bit buggy so I'm using MX-15/Xfce as my main presently. siduction will have a new version soon with Plasma 5.6 so I'm eager to try it. Still, KDE4 was not excellent till 4.10. 1 Quote Link to comment Share on other sites More sharing options...
Dr. J Posted June 12, 2016 Share Posted June 12, 2016 I don't imagine DE has much to do with it. Could have been a (tiny) chance that a dependency in there had something to do with it. I guess not though. Quote Link to comment Share on other sites More sharing options...
