20 Unix Command Line Tricks – Part I
Let us start new year with these Unix command line tricks to increase productivity at the Terminal. I have found them over the years and I'm now going to share with you.
Deleting a HUGE file
I had a huge log file 200GB I need to delete on a production web server. My rm and ls command was crashed and I was afraid that the system to a crawl with huge disk I/O load. To remove a HUGE file, enter:
> /path/to/file.log
# or use the following syntax
: > /path/to/file.log
# finally delete it
rm /path/to/file.log
Want to cache console output?
Try the script command line utility to create a typescript of everything printed on your terminal.
script my.terminal.sessio
Type commands:
ls
date
sudo service foo stop
To exit (to end script session) type exit or logout or press control-D
exit
To view type:
more my.terminal.session
less my.terminal.session
cat my.terminal.session
Restoring deleted /tmp folder
As my journey continues with Linux and Unix shell, I made a few mistakes. I accidentally deleted /tmp folder. To restore it all you have to do is:
mkdir /tmpchmod 1777 /tmpchown root:root /tmpls -ld /tmp
Locking a directory
For privacy of my data I wanted to lock down /downloads on my file server. So I ran:
chmod 0000 /downloads
The root user can still has access and ls and cd commands will not work. To go back:
chmod 0755 /downloads
Password protecting file in vim text editor
Afraid that root user or someone may snoop into your personal text files? Try password protection to a file in vim, type:
vim +X filename
http://www.cyberciti...-tricks-part-i/
