Unbuntu File and Screen Problem
Robert
There I was at the University of South Carolina website downloading images, when Ubuntu started giving nautilus crash messages. Rebooting fixed the problem, for a few minutes at a time, then I got this screen and all hope was lost:
http://imgur.com/eWQy4sM
All I had been doing is downloading newspaper images like this:
http://chroniclingamerica.loc.gov/lccn/sn93067853/1906-07-27/ed-1/seq-1/
Something about having those files on the computer causes the screen to mess up.
I thought I would have to reinstall Ubuntu, but I found that by hooking up the Ubuntu drive as a slave drive to Fedora, I was able to delete the image files (.jpg) of the newspapers. That fixed everything.
I experimented a bit first. Deleting the jpg file from the Ubuntu desktop fixed the screen problem, but having a copy of it in the downloads folder still crashed nautilus if I selected that folder.
Weird.
Obviously, there was more in the file downloaded than a simple image.
Can you examine the meta-data and other non-image info in the file?
I'm not downloading from that website using Ubuntu. I still have the files on the Fedora drive so will take a look later. Is there anything I need to know to look at the meta-data?
Where did you get the jpg files as the download links list pdf, text and jp2 (which is essentially a type of jpeg)?
I downloaded the jp2 file and it opened with gimp just fine. Perhaps this is a bug with nautilus and jp2 file but that would be too common not to be fixed.
Here is the exiftool output on the same image as you linked to:
I had to use an image as it wouldn't line up right on code or quote pastes. Here is a link to the output: http://ix.io/Udx
I gave it a try but I can't get the Exif program to work.
More info on the original problem:
I had downloaded the same files twice so it was automatically named seq-1(1).jp2
Could the extra brackets in the file name cause such problems?
No, that would of not affected anything.
sed s/of/have/
I have an autobot set up to do this every time it occurs. ;)
Right.... :hysterical:
