Have Questions about VM's
43 replies to this topic
#26 OFFLINE   raymac46
  • 3,466 posts
Posted 22 April 2017 - 10:04 PM
With regard to Cinnamon in rendering mode you may get that in Virtualbox anyway since it's a software 3D rendereing llvmpipe. Have a look at my Manjaro hardware report.
[ray@ray-pc ~]$ inxi -Fxz
System: Host: ray-pc Kernel: 4.9.22-1-MANJARO x86_64 (64 bit gcc: 6.3.1)
		 Desktop: Xfce 4.12.3 (Gtk 2.24.31) Distro: Manjaro Linux
Machine: Device: oracle System: innotek product: VirtualBox v: 1.2
		 Mobo: Oracle model: VirtualBox v: 1.2
		 BIOS: innotek v: VirtualBox date: 12/01/2006
CPU:	 Dual core Intel Core i5-2320 (-MCP-) cache: 6144 KB
		 flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3) bmips: 11977
		 clock speeds: max: 2993 MHz 1: 2993 MHz 2: 2993 MHz
Graphics: Card: InnoTek Systemberatung VirtualBox Graphics Adapter
		 bus-ID: 00:02.0
		 Display Server: X.Org 1.19.3 driver: modesetting
		 Resolution: 1920x975@59.93hz
		 GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits)
		 GLX Version: 3.0 Mesa 17.0.3 Direct Rendering: Yes
Audio:	 Card Intel 82801AA AC'97 Audio Controller
		 driver: snd_intel8x0 ports: d100 d200 bus-ID: 00:05.0
		 Sound: Advanced Linux Sound Architecture v: k4.9.22-1-MANJARO
Network: Card: Intel 82540EM Gigabit Ethernet Controller
		 driver: e1000 v: 7.3.21-k8-NAPI port: d010 bus-ID: 00:03.0
		 IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 17.2GB (66.3% used)
		 ID-1: /dev/sda model: VBOX_HARDDISK size: 17.2GB
Partition: ID-1: / size: 12G used: 6.6G (60%) fs: ext4 dev: /dev/sda1
		 ID-2: swap-1 size: 4.63GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: None detected - is lm-sensors installed and configured?
Info:	 Processes: 132 Uptime: 0 min Memory: 311.9/2004.9MB
		 Init: systemd Gcc sys: 6.3.1
		 Client: Shell (bash 4.4.121) inxi: 2.3.8
[ray@ray-pc ~]$
Edited by raymac46, 22 April 2017 - 10:06 PM.
Registered Linux User 445659
#27 OFFLINE   securitybreach
  • 23,255 posts
Posted 22 April 2017 - 10:06 PM
View Postraymac46, on 22 April 2017 - 10:02 PM, said:
pacman-mirrors -g works just fine in Manjaro.
That is only an alias for rankmirrors: https://wiki.manjaro...date_Mirrorlist
Is that what they refer to it as or is that just your wording for the output of inxi on Manjaro?
#28 OFFLINE   securitybreach
  • 23,255 posts
Posted 22 April 2017 - 10:14 PM
Here is that output on my main rig:
http://ix.io/rwG
#29 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,160 posts
Posted 22 April 2017 - 10:28 PM
Here is mine
Mel
inxi -Fxz
System:    Host: m-pc Kernel: 4.9.13-1-MANJARO x86_64 (64 bit gcc: 6.3.1)
   Desktop: Cinnamon 3.2.8 (Gtk 3.22.9) Distro: Manjaro Linux
CPU:    Dual core AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G (-MCP-) cache: 4096 KB
   flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3) bmips: 12377
   clock speeds: max: 3093 MHz 1: 3093 MHz 2: 3093 MHz
   bus-ID: 00:02.0
   Display Server: X.Org 1.19.2 driver: modesetting
   Resolution: 1280x618@59.80hz
   GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)
   GLX Version: 3.0 Mesa 17.0.1 Direct Rendering: Yes
   Sound: Advanced Linux Sound Architecture v: k4.9.13-1-MANJARO
Drives:    HDD Total Size: 8.6GB (58.3% used)
   ID-1: /dev/sda model: VBOX_HARDDISK size: 8.6GB
Partition: ID-1: / size: 7.9G used: 4.7G (64%) fs: ext4 dev: /dev/sda1
Info:   Processes: 126 Uptime: 6 min Memory: 781.8/2005.0MB
Registered Linux User #239772
#30 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,160 posts
Posted 22 April 2017 - 10:57 PM
can't download the updates now because of the following error. there are 163 updates.
now I get a error.
could not satisfy dependencies Lib32- glu installing mhwd breaks lib32-libgl
#31 OFFLINE   raymac46
  • 3,466 posts
Posted 23 April 2017 - 06:38 AM
1. It works whatever you want to call it.
2. Yes my term for it. Call it inxi if you want. Same difference as far as I am concerned.
Edited by raymac46, 23 April 2017 - 06:44 AM.
#32 OFFLINE   raymac46
  • 3,466 posts
Posted 23 April 2017 - 06:44 AM
now I get a error.
https://www.reddit.c...ncies_issue_on/
This has nothing to do with VBox and could be an issue on the rails as well. It's a Manjaro thing.
Edited by raymac46, 23 April 2017 - 06:51 AM.
#33 OFFLINE   securitybreach
  • 23,255 posts
Posted 23 April 2017 - 08:08 AM
I only asked because inxi came out about 7 years before Manjaro. I brought that up is because Manjaro has been caught labeling something as their own and was called out for it in the past for it.
#34 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,160 posts
Posted 23 April 2017 - 08:10 AM
now I get a error.
Ray I want to thank you and the other members, for all your time and trouble. I am sorry, but Manjaro until it is more mature, will not be a distro for me. to many problems and there are other distros that work with very few problems. I did the fix as per reddit, but there were still other problems and dependencies needed. This is a Distro to much like Arch with all its problems. Linux distros should be fun and work pretty much right out of the box and not be a chore to get to work correctly. I guess I will just try to stick with Debian / Ubuntu type distros for now. Anyway thanks to all for your help.
Mel
#35 OFFLINE   securitybreach
  • 23,255 posts
Posted 23 April 2017 - 08:12 AM
now I get a error.
Mel
Well honestly you will not see many of the issues with Manjaro on Archlinux. The reason for this is because Manjaro holds back packages and on a rolling distro, doing this can and will cause issues with versioning/compatibility with other packages. So do not get the wrong idea about archlinux based on a derivative with too many changes. That is like blaming Debian for Ubuntu's failures.
#36 OFFLINE   securitybreach
  • 23,255 posts
Posted 23 April 2017 - 08:21 AM
For instance, the error you got only occured on Manjaro and not Archlinux.
#37 OFFLINE   raymac46
  • 3,466 posts
Posted 23 April 2017 - 08:36 AM
Josh is right. Arch can be set up as simply as you want or as complex as you want. Manjaro has a bunch of special tools that sometimes give problems - like mhwd. I haven't had any difficulties lately but I don't use it in any other way but as a Virtual Machine. I wouldn't put it on anything I wanted to use say on vacation.
A good candidate for VBox is MX-16 - nice desktop and Guest Additions work. Lubuntu is another. Linux Mint Xfce is another.
#38 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,160 posts
Posted 23 April 2017 - 08:44 AM
OK I will agree, it is not Arch fault. I have Lubutu, and Fedora both running in a VM without problems. I also have a VM in windows 10 and some surprises which I will leave for another post.
Mel
#39 OFFLINE   raymac46
  • 3,466 posts
Posted 23 April 2017 - 10:08 AM
I like Siduction very much in VM but unfortunately their last release had a bug where they removed the Guest Additions if you installed it. It worked fine as a Live image.
#40 OFFLINE   saturnian
saturnian
    Multithreader
  • 1,026 posts
Posted 23 April 2017 - 10:32 AM
Exactly. I've been running Antergos, which is a lot closer to Arch than Manjaro is, but still not quite the same thing as what I'm seeing in my Arch installation.
This is a great thread. Mostly, though, it's made me realize that I have no need to mess around with VMs at this time.
Also, no Windows here, which I'm happy about.
#41 OFFLINE   raymac46
  • 3,466 posts
Posted 23 April 2017 - 03:58 PM
Haven't lost my touch I guess. I did an Arch install in VBox on Linux Mint 18.1 This is what I have so far. Installed gdm so I have GNOME and also Xfce.
#42 OFFLINE   raymac46
  • 3,466 posts
Posted 24 April 2017 - 02:57 PM
I decided I'd rather have my Arch VM hosted on Windows 10 so I reinstalled it. I think I did a better job this time. I used LightDM as my display manager and have only installed Xfce. I have sound working and got the browsers, Abiword and Gnumeric and VLC installed.
If you're interested in fooling around with VMs it's really worth it to install Arch.
#43 OFFLINE   Peachy
Peachy
    Anarquista De Sartorial
  • 5,440 posts
Posted 12 May 2017 - 12:14 AM
At work I just built a new cluster consisting of 5 Dell R630 servers running VMware vSphere Hypervisor managed using vCenter Server. The cluster pool has a total of 160 vCPUs and 1.25TB of memory and I have 24TB of iSCSI storage available to it over a 10GB Ethernet fabric. I should be able to virtualize 1,000+ virtual machines! :devil: :devil: :devil:
#44 OFFLINE   securitybreach
  • 23,255 posts
Posted 12 May 2017 - 11:47 AM
Very nice!! I need something like that at home.... B)
