réjean Posted August 26, 2012 Share Posted August 26, 2012 Hi all! I installed slackware 13.37 and left the bootloader on / ( dev /sda10 ). I managed to mount the partition in Mandriva 2011 and managed to remember that lilo.conf is in /etc. So I copied the entry; title slackware image = /boot/vmlinuz root = /dev/sda10 label = Linux read-only but when I try to boot into it I get an; error 11. Unrecognized device string. In /boot I saw a vmlinuz -generic-2.6.37.6, a vmlinux -huge-2.6.37-6, a system.map -generic-2.6.37.6 and a system.map -huge-2.6.37.6. How can I change the entry in mandriva /boot/grub/menu.lst so that I can boot into slackware. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted August 26, 2012 Share Posted August 26, 2012 If you are using Grub-legacy, then add this to Mandriva's menu.lst file title Slackware root (hd0,10) kernel /<vmlinuz_filename> ro root=/dev/sda10 initrd /<initrd_filename> Check the slackware /boot folder and replace the kernel and initrd with the correct vmlinuz and initrd filenames. Then save the file and reboot machine. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted August 26, 2012 Share Posted August 26, 2012 Slack probably installed with the huge kernel by default. You won't need to boot with an initrd when running huge. title slackware root (hd0,9) kernel /boot/vmlinuz root=/dev/sda10 ro NOTE: The only time you need to install the bootloader to the / partition when installing a Linux distribution is when you plan on chainloading using GRUB. The entry above is a direct boot, not a chainload. This is the better way to do it, in my opinion. However, different strokes... 1 Quote Link to comment Share on other sites More sharing options...
réjean Posted August 26, 2012 Author Share Posted August 26, 2012 (edited) @josh! I knew that I hadn't seen an 'initrd'file but I couldn't remember using 'kernel' either. @Eric. Thanks! I got in although I had to make a slight change because I have some distros that see a hda drive (IDE) and a sda (SATA) others see a sda and a sdb, not only that but one is call sda in one distro and sdb in the other or vice-versa. Anyway 'sdb10' did the trick. I am actually replying from slackware using konqueror. 2 quick questions if I may; 1. at login time I had rejean login: to which I replied 'rejean' and entered my password but it didn't work so I am now login as 'root'. Should I do a 'adduser' thing and create a 'rejean' user? 2. Finally do you mean that when I install a new distro I can just not install a bootloader at all and then just create an entry in the bootloader I am actually using? Edited August 26, 2012 by réjean Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted August 26, 2012 Share Posted August 26, 2012 1. Yes, in Slack, you have to create a user account once you've completed the installation and booted up the initial time. # adduser Follow the prompts. 2. Yes. That is how I boot ALL distributions on my system. Arch controls the MBR on the boot drive on my main system and uses legacy GRUB. I installed my other distributions (Slackware, CentOS, Debian-Sid, Linux Mint, Salix) to their respective partitions. Afterwhich, I created the direct menu.lst entries to boot each one directly. My Arch GRUB menu.lst: # Config file for GRUB - The GNU GRand Unified Bootloader# /boot/grub/menu.lst # # general configuration: # timeout 5 default 0 # # pretty colors: # # color light-blue/black light-cyan/blue # color cyan/blue white/blue color white/black blue/black # color white/black red/black # color white/black white/cyan # color white/black black/white # color light-blue/black white/blue # # # bootable operating systems follow: # # IMPORTANT --> arch GRUB sees hard drives as /dev/sda=hd0, /dev/sbd=hd2, /dev/sdc=hd1 ~vtel57-042011 # # (1) Slackware64-13.37 title slackware root (hd0,0) kernel /boot/vmlinuz root=/dev/sda1 ro initrd /boot/initrd.gz # # (2) Arch64 title arch root (hd0,4) kernel /boot/vmlinuz-linux root=/dev/sda5 ro initrd /boot/initramfs-linux.img # (3) MS Windows XP/SP3 title windows root (hd2,0) map (hd0) (hd2) map (hd2) (hd0) chainloader +1 # (4) CentOS64 5.6 title centos (t1) root (hd2,5) kernel /boot/vmlinuz-2.6.18-308.11.1.el5 root=/dev/sdb6 ro initrd /boot/initrd-2.6.18-308.11.1.el5.img # (5) Debian64 6.0.4 "Sid" title debian (t2) root (hd2,7) kernel /boot/vmlinuz-3.2.0-1-amd64 root=/dev/sdb8 quiet initrd /boot/initrd.img-3.2.0-1-amd64 # (6) Linux Mint 12-64 title linux mint (t3) root (hd2,9) kernel /boot/vmlinuz-3.0.0-12-generic root=/dev/sdb10 ro initrd /boot/initrd.img-3.0.0-12-generic # (7) Salix64 13.37 title salix (t4) root (hd2,11) kernel /boot/vmlinuz-huge-2.6.37.6 root=/dev/sdb12 ro initrd /boot/initrd.gz # (8) Shutdown title --> 0 halt Everyone has their favorite way. Bruno preferred installing the bootloader to the / partition and then chainloading distros. I prefer to direct boot them. It's all good, just depends on what you find easiest for you. 1 Quote Link to comment Share on other sites More sharing options...
