Mandrake 10 Install so near
543 replies to this topic
#26 OFFLINE   Bruno
Bruno
    Le Professeur Pingouin
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 06:24 PM
Have you got TweakUI ??B) Bruno
#27 OFFLINE   ross549
ross549
    I live here.
  • 9,185 posts
Posted 20 May 2004 - 06:28 PM
Colin,In the General tab of Internet options, you have the middle box for Temporary Internet Files. Click on the settings button, and in the window that comes up, click on move folder. That will give you your drives and subfolders that you can put your TIF in.I would suggest you click on the button to delete the files first though, befre you move the folder. B)
Edited by ross549, 20 May 2004 - 06:29 PM.
#28 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 06:30 PM
No Bruno no tweakuibut rebooted and swap file done B) now just to find the inet cache againcolin  :medic:
Registered Linux User: # 440412
Kamicotas Homepage
#29 OFFLINE   ross549
ross549
    I live here.
  • 9,185 posts
Posted 20 May 2004 - 06:31 PM
Colin, see my post above yours.
#30 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 06:37 PM
Thanks Et-AlsBoth are done and am back in Windows Firefoxcolin   B)  :medic:  :medic:
Kamicotas Homepage
#31 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
Posted 20 May 2004 - 06:41 PM
B)  :medic:  :medic:
#32 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
if you need any help, just post....  some of us are still here B)
#33 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
ColinI will be off line soon . . . Before you start: Do you have a boot-CD for PCLos ?? And does it work ??We want to be sure you do NOT overwrite hda1, hda7, hda8 and hda9hda1 = Windowshda7 = Mepishda8 = swaphda9 = PCLosSo resize hda5 and hda6 . . those are the "free" partitions . . . and rezize them with the Mandrake installer tool while doing the install . . Good night . . . see you tomorrow !B) Bruno
#34 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 06:43 PM
Thanks BrunoWill catch you tomorrowI have the PCLos RESCUE CD If that's what you meanI'm off back into PCLos for the hard drive infoColin
Kamicotas Homepage
#35 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 06:48 PM
I figured out the HD info for you from previous threads Colin:hda1 = C: Windowshda5 = D:hda6 = E:hda7 = Mepishda8 = swaphda9 = PCLos
#36 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 06:53 PM
Thanks BrunoNow struggling with "Do I need to Uninstall More Programms that are on D"Did about  6 this afternoon and wondering if I leave some on D and do NOT  uninstall WILL that affect the Windows rebooting and What will happen with PCLos Lilo B)  :medic:  :medic:  Colin as usual
Kamicotas Homepage
#37 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
Posted 20 May 2004 - 06:57 PM
how much free space do you have on D?if you have enough, you don't need to uninstall any more...  Just resize and go...  won't affect anything B)
#38 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 07:01 PM
DEFRAG the D drive though !!B) Bruno
#39 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 07:02 PM
Now RyanHadn't thought of that BUT which part of the resizing would I put MDK 10???Also It may be appropriate to an Ontracks version of Symantecs Windoctor  first as I Have Ontracks System Suite Colin B)
Kamicotas Homepage
#40 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 07:03 PM
BrunoI use System Suite SO are you suggesting a Windows defrag First of D Colin
Kamicotas Homepage
#41 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
Posted 20 May 2004 - 07:05 PM
yes, you should defrag D first....doesn't matter which part of the two partitions you put Mandrake on...
#42 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 07:07 PM
Well ryan/BrunoIt's back into windows for either a Windows Defrag of D or whatever it is in System SuiteFingers Crossed  B)  OOPS that was the EYESColin  :D
Kamicotas Homepage
#43 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
Posted 20 May 2004 - 07:09 PM
I don't know system suite, so can't help you with it, but I do recommend using the standard windows defrag (Start->Programs->Accessories->System Tools-> Defrag)
#44 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 07:10 PM
ColinWhile you are in Windows:Print this out:hda1 = C: Windowshda5 = D:hda6 = E:hda7 = Mepishda8 = swaphda9 = PCLos And stick it on your monitor !B) Bruno
#45 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 07:13 PM
Sure will BrunoBut just remembered  :D  bruno MDK 10 Install sheets that I have may change here as I have to resize etcOH BOY  :)  :w00t:  :w00t:  what am I letting myself in for againColin  B)
Kamicotas Homepage
#46 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 07:16 PM
Colin:6th screen: The DrakX Partitioning wizard found etc. etc.  . . there you choose "costom disk partitioning" . . that is the only change in the "how-to"B) Bruno
#47 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 20 May 2004 - 07:18 PM
Great BrunoWill have this all beside me after i do an Ontrack's System Suite JetDefrag on "D"This wont affect my PCLos Lilo will it Bruno if so it may wiser to leave it till tomorrow Colin
Kamicotas Homepage
#48 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 07:21 PM
It will sure overwrite your PCLos lilo . . that is why you have the rescue CD for PCLos . . . B) Bruno
#49 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 20 May 2004 - 07:22 PM
PART 2You better listen to Ryan and use the default Windows defragger . . and not the Ontrack's System Suite JetDefragB) Bruno
#50 OFFLINE   kamicota
kamicota
  • 8,358 posts
OH BOY  B) Palpitations already BrunoColin  :D
Kamicotas Homepage
