Windows XP Service Pack 3, Checked Build
18 replies to this topic
#1 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 06 May 2008 - 03:43 PM
Is this the final one?...http://www.microsoft...;displaylang=en
#2 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,542 posts
Posted 06 May 2008 - 03:56 PM
The page cannot be foundThe page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
huh.  the site must be busy!and at 350mb, i guess it is!!
#3 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 06 May 2008 - 04:04 PM
It was there under New Downloads in Download centre and now it got disappeared.
Edited by Drifter, 06 May 2008 - 04:04 PM.
#4 OFFLINE   zlim
zlim
    It's me, plodr
  • 7,111 posts
Posted 06 May 2008 - 06:13 PM
You can download it from herehttp://www.majorgeek...wnload4323.htmlit's a wee bit smaller; it excludes a few things. Let me check what they are.
Liz
#5 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 06 May 2008 - 06:33 PM
after few tries I was able to download it from the MS site...this is the file I got windowsxp-kb936929-sp3-x86-debug-enu.exe
#6 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 06 May 2008 - 06:49 PM
Think this is the correct one......Windows XP Service Pack 3 Network Installation Package for IT Professionals and Developers
#7 OFFLINE   alphaomega
alphaomega
    Multithreader
  • PipPipPipPipPipPipPipPip
  • 1,012 posts
Posted 06 May 2008 - 08:06 PM
View PostDrifter, on May 6 2008, 05:49 PM, said:
So...is this the one to use if you are installing on only one computer?I know it mentions to visit the Windows Update site...but the computer in question is still on dial-up.
#8 OFFLINE   kkehoe
kkehoe
    Post Master
  • PipPipPipPip
  • 220 posts
Posted 06 May 2008 - 09:08 PM
It doesn't really matter if you use Windows Update or do the manual download - the results will be the same.  The only reason Microsoft distinguishes the full download from the WU version is that they'd rather have the "average" 1-computer family downloading the 60-70MBs via WU rather than have everybody in the world downloading the full SP.That said, with a dial-up computer, I'd get to another PC with a broadband connection, download the full SP, burn it to a CD and install it on the dial-up computer.Kevin
#9 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 06 May 2008 - 09:21 PM
That is what I'm doing...I just wanted to make sure I got the correct one.Or will either work for me?
#10 OFFLINE   Guitar Man
Guitar Man
    Thread Head
  • 745 posts
Posted 06 May 2008 - 10:50 PM
Either will *normally* work. Normal in Microsoft terms depends on what is the state of your system prior to downloading and installing a behemoth service pack such as SP2 or SP3.I've been using (and promoting the use of) the network install for anyone not getting the warning via WU/MU. But that's me... :whistling: The network file size is the one you want if you are going to slipstream a copy with your XP install for future needs. Maybe MS will be offering a free SP3 CD like they did for SP2 ?I just got the 'Notify' warning via the yellow shield in the systray, and will create a manual restore point before giving it a go. I know that a restore point will be made in the install process, but...just to be on the safe side... :)
#11 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 07 May 2008 - 07:08 AM
I got the warning thru' the yellow shield in systray to install SP3 yesterday and I clicked the download button but the icon got disappeared from the tray. I waited for another one hour thinking that its getting downloaded in the background but nothing happened.So I went to Windows update site but the only option their was to install WGA....Then I found the link in MS website. I got it installed without any trouble. The only difference I see is explorer is bit too slow in listing files.
#12 OFFLINE   hkspike
hkspike
    Message Mogul
  • PipPipPipPipPip
  • 412 posts
Posted 07 May 2008 - 09:14 AM
I went looking for trouble: SP3 was offered on Windows Update with a warning not to download any other patch til SP3 installed. For a notional, it said, 66Mb, it took a long while to download and install on my laptop. Haven't seen many changes; should I expect many?
If you try and take a cat apart to see how it works, the first thing you have on your hands is a non-working cat.
#13 OFFLINE   NICK ADSL UK
NICK ADSL UK
    Message Adept
  • PipPipPip
  • 61 posts
Posted 07 May 2008 - 11:50 AM
Windows XP Service Pack 3 Network Installation Package for IT Professionals and Developershttp://www.microsoft.....isplayLang=enWindows XP Service Pack 3 - ISO-9660 CD Image Filehttp://www.microsoft.....isplayLang=enWindows XP Service Pack 3 Overviewhttp://www.microsoft.....isplayLang=enWindows XP Service Pack 3 MUI Pack Updatehttp://www.microsoft.....isplayLang=enSMS Template Files for Windows XP Service Pack 3 Deploymenthttp://www.microsoft.....isplayLang=enWindows XP Service Pack 3, Checked Buildhttp://www.microsoft.....isplayLang=enRelease Notes for Windows XP Service Pack 3http://www.microsoft.....isplayLang=en
#14 OFFLINE   Drifter
Drifter
    Post Master
  • PipPipPipPip
  • 146 posts
Posted 07 May 2008 - 01:24 PM
The ISO file (544.9 MB) looks larger than the others???
#15 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,542 posts
Posted 08 May 2008 - 12:51 PM
i installed via windows update.  (start, all programs, windows update)it downloaded and installed in 20 minutes.  not bad!my "about windows" now says:Version 5.1 (Build 2600.xpsp.080413-2111: Service Pack 3)i'd heard sp3 is supposed to let xp run faster... if so, i haven't noticed that...  or any other side effects, yet.ms office 2003 and eset nod32 av seem to run ok on it...  anyone else have observations?
#16 OFFLINE   Tarq57
Tarq57
    Message Adept
  • PipPipPip
  • 99 posts
Posted 11 May 2008 - 04:15 AM
Downloaded and saved from MS download site, same as the top link in Nick's post above. Download 11min, install about 25, including reboot. No problems at all, in fact, XP may possibly be a little faster. Also using Avast Home, CFP 3, Threatfire, Comodo Memory Firewall, Secunia PSI, all OK.
#17 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,542 posts
Posted 11 May 2008 - 01:23 PM
other than the laptop not fairing well with sp/3, i've heard no real bad stuff about it...
#18 OFFLINE   zlim
zlim
    It's me, plodr
  • 7,111 posts
Posted 11 May 2008 - 06:24 PM
Some people are having major problems with it.endless reootshttp://www.dslreport...endless-rebootsstop errorhttp://support.microsoft.com/kb/888372prolems with some AMD computershttp://msinfluential...ing-xp-sp3.aspx
Liz
#19 OFFLINE   Temmu
Temmu
    The Assimilator
  • 12,542 posts
Posted 13 May 2008 - 01:57 PM
View Postzlim, on May 11 2008, 05:24 PM, said:
Some people are having major problems with it.endless reoots...
oooo i hates me some endless re-oots!   B) temmu runs like crazyagh!  no, liz, no!  don't do it![fade to black]
