Neil P Posted September 3, 2005 Share Posted September 3, 2005 I don't know if anyone remembers my issues from last year, where I couldn't get on the internet (the reason I had to switch to Fedora in the first place).Well, now I'm in Mepis, and I've got new issues.The package to install the AEGIS client is an rpm. So, I went to install it, and it told me to run 'alien' to install an rpm in Debian. Okay, no big deal, I ran that and it gave me a .deb to use. So, after installing that, I was able to get to the client (installed under /usr/local/aegisc/bin/AEGISclient). After an issue with setting JAVA_HOME (quick hit: how can I get JAVA_HOME to always be set, instead of exporting it each time I try to run it? I'm sure it's a file somewhere, but I can't remember where ), I was able to run the client.Then the real problem started. It comes with its own module, svc8021x, that apparently was not installed. Now, at this point, I should have just rebooted into Windows here and asked for help, but instead I tried to work with it myself. Now, I believe I copied svc8021x into /etc/modules (possibly that's /etc/modutils, though I'm not sure ), and I also ran update-modules several times. Obviously, I didn't go about this right.However, through some magic or luck, I was able to get the client to start, and it didn't complain about the missing service (therefore I assumed that I had installed it correctly), so I tried to authenticate. At first, I was given a network error, but after ifconfig eth0 up, I was able to authenticate to the network. Usually, at this point I'm done, and able to get online.Today, nothing. I get unknown host errors everywhere, and I can't do anything. The AEGIS Client is claiming I'm authenticated, so I'm at a loss here.Any ideas? Am I possibly missing something small? Do I need to actually install svc8021x properly? I'd like to use linux to access the network here at school, and the only way is with the client. Quote Link to comment Share on other sites More sharing options...
ross549 Posted September 3, 2005 Share Posted September 3, 2005 Neil......Did you modprobe the module into use? You may also have to add to to /etc/modprobe.preload to force it to load on each boot. Quote Link to comment Share on other sites More sharing options...
Neil P Posted September 3, 2005 Author Share Posted September 3, 2005 I tried to "modprobe svc8021x" but it didn't work. I, for whatever reason, couldn't get it to work. Do I need to have it (svc8021x) in a certain place? Quote Link to comment Share on other sites More sharing options...
Bruno Posted September 3, 2005 Share Posted September 3, 2005 Hi NeilUsually the drivers/modules go in a directory related to the kernel you are running . . so for example:"/lib/modules/2.6.11-12/kernel/drivers/net/"Once it is there you should be able to "modprobe" it and after that check if it really is loaded with "lsmod"Now I am asking myself: that svc8021x is that a file or a directory ? Because if it is a directory it might belong in "/sys/modules"Next: quick hit: how can I get JAVA_HOME to always be set, instead of exporting it each time I try to run it? You might try to add a line to "/etc/rc.boot" ( a file typically for Debian, the same as the /etc/rc.local in Fedora ) An alternative location is "~/.bash_profile", "~/.bashrc" or "/root/.bash_profile" ( depending on who has to run it ) Bruno Quote Link to comment Share on other sites More sharing options...
Neil P Posted September 3, 2005 Author Share Posted September 3, 2005 Okay...so now I'm thinking it's not actually a module, and I've just got my terms confused.I'm currently online in MEPIS, and this is what I did: First, I set JAVA_HOME in ~/.bashrc.After that, all I did was, as root, /usr/local/aegisc/bin/svc8021x, and then as user /usr/local/aegisc/bin/AEGISClient.Once I brought that up, I tried to authenticate. At the same time, through the OS Center, I activated eth0, and once it authenticated, I was online.So, I guess the question is, how can I get svc8021x to run at boot/everytime? Quote Link to comment Share on other sites More sharing options...
Bruno Posted September 3, 2005 Share Posted September 3, 2005 Hi NeilJust open the file "/etc/rc.boot" and add this line at the bottom of the file: /usr/local/aegisc/bin/svc8021x And it will run every time you boot :DB) Bruno Quote Link to comment Share on other sites More sharing options...
Neil P Posted September 3, 2005 Author Share Posted September 3, 2005 I'll try that in a second, Bruno :)I've got another quick question, though. My monitor is an Envision LCD, with a native resolution of 1280x1024. The previous monitor I had was a CRT, with a resolution of 1024x768. Now, I couldn't find Envision in the OS Center's Mouse and Display configuration, so I just picked "Generic LCD - LCD Panel 1280x1024", hit apply, and restarted X. However, KDE is still using 1024x768. If I right click on the Desktop and hit Configure Desktop, and then the Display tab, the largest value for "screen size" is 1024x768, and no higher. How can I get KDE to recognize that 1280x1024 is my resolution? Quote Link to comment Share on other sites More sharing options...
Bruno Posted September 3, 2005 Share Posted September 3, 2005 Hi NeilYou will have to check your /etc/X11/xorg.conf file . . . . see what the DefaultDepth is and add the 1280x1024 value to the line corresponding with that Depth value . . . . example: Section "Screen"    Identifier   "Default Screen"    Device     "Generic Video Card"    Monitor     "Samsung"    DefaultDepth  24 <<========================= !!    SubSection "Display"        Depth      1        Modes      "800x600" "640x480"    EndSubSection    SubSection "Display"        Depth      4        Modes      "800x600" "640x480"    EndSubSection    SubSection "Display"        Depth      8        Modes      "800x600" "640x480"    EndSubSection    SubSection "Display"        Depth      15        Modes      "800x600" "640x480"    EndSubSection    SubSection "Display"        Depth      16        Modes      "1280X1024" "1024x768" "800x600" "640x480"    EndSubSection    SubSection "Display"        Depth      24 <<========================= !!        Modes      "1280X1024" "1024x768" "800x600" "640x480"    EndSubSectionEndSection Bruno Quote Link to comment Share on other sites More sharing options...
Neil P Posted September 3, 2005 Author Share Posted September 3, 2005 Hi NeilJust open the file "/etc/rc.boot" and add this line at the bottom of the file: /usr/local/aegisc/bin/svc8021x And it will run every time you boot :DB) Bruno <{POST_SNAPBACK}> Bruno, I have no /etc/rc.boot Adding those lines to /etc/X11/XF86Config-4 worked great, thanks! Quote Link to comment Share on other sites More sharing options...
Bruno Posted September 3, 2005 Share Posted September 3, 2005 I have no /etc/rc.boot <{POST_SNAPBACK}> NO ?? . . And Mepis is Debian based ??? . . . . Well then we need to do another trick . . . Make a bash-script ( see http://forums.scotsnewsletter.com/index.ph...=14&t=503&st=56 ) make it executable and place it in the /etc/init.d directory, then place a symlink in the /etc/rcS.d directory and add before the name an S ( S=start K=kill ) and a number ( for the order of starting up, see the other symlinks in that directory and you will see what I mean ) So example: /etc/rcS.d/S90Mysvc8021x is the link that points to /etc/init.d/Mysvc8021x and will be one of the last in line to start up ( hence "90" . . . if you make that "20" it will be one of the first )Can you follow that line of thoughts or do you want me to post step by step intructions ?Note: the bash script needs only 2 lines: #!/bin/bash /usr/local/aegisc/bin/svc8021x ( you can add the 3rd line: "#End script" but it is not really needed ) Bruno Quote Link to comment Share on other sites More sharing options...
Neil P Posted September 3, 2005 Author Share Posted September 3, 2005 I think I've got it, thanks a bunch Bruno! Quote Link to comment Share on other sites More sharing options...
Bruno Posted September 3, 2005 Share Posted September 3, 2005 LOL . . . I just finished re-writing the procedure . . . ( so I will post it anyway ):We make a little bash script: # vi /etc/init.d/Start_svc8021x This is the content of the script: #!/bin/bash /usr/local/aegisc/bin/svc8021x#End scriptThen save the file and make it executable:# chmod 755 /etc/init.d/Start_svc8021x And put it on a place where it will run whe you boot your computer: # ln -s /etc/init.d/Start_svc8021x /etc/rcS.d/S90Start_svc8021x BrunoPS: Sure you can add more lines to the script if you want to automate the start of other items too ( for example activate eth0 ) . . . . a line with "sleep 2" will make it pause 2 sec between commands.PS2: If even " /etc/rcS.d/" is missing . . .( what would be very unusual for debian based distros, but since you miss /etc/rc.boot as well ). . . . . you can use " /etc/rc5.d/" which will start it in runlevel 5 Quote Link to comment Share on other sites More sharing options...
