normanlp Posted May 11, 2003 Share Posted May 11, 2003 I am having problems installing D-Link's DSB-C100 Webcam. I am running Windows 98SE.I go through the installation procedures and I insert my Windows CD when asked but the installation program is unable to locate file iyuv_32.dll.I did a google search and most of the dll sites do not show this file. A couple of the sites show this file as part of the Windows XP driver.Can anybody help me locate this file and also where would I put it so that the installation program would pick it up.I also have a logitech QuickCam Express installed, I don't think that this has any bearing on my problem though. I mentioned it just in case.Thank you ....... Norm Quote Link to comment Share on other sites More sharing options...
Stryder Posted May 11, 2003 Share Posted May 11, 2003 1. Have you gone to D-links site and downloaded the latest drivers there?2. Have you tried the install without the other Cam plugged in? Quote Link to comment Share on other sites More sharing options...
Guest ThunderRiver Posted May 11, 2003 Share Posted May 11, 2003 iyuv_32.dll really has nothing to do with Windows Xp. It is actually Intel Indeo® Video YUV Codec, and most Microsoft games (such as Flight Simulator) uses that codec. You should do a search on it. I believe that codec is freeTechnically, if you can grab such file from Windows Xp, the code should still work. But you have to try it and see. http://www.codec-download.de/modules.php?n...download&cid=11 Provides a YUV codec, but there is no guarantee that it works. Perhaps you could find the codec right off your driver CD? Quote Link to comment Share on other sites More sharing options...
