Corrine Posted July 12, 2016 Share Posted July 12, 2016 Adobe has security updates for Adobe Reader and Acrobat XI for Windows and Macintosh. Adobe has security updates for Adobe Reader and Acrobat XI for Windows and Macintosh. These updates address critical vulnerabilities that could potentially allow an attacker to take control of the affected system. Update checks can be manually activated by choosing Help > Check for Updates. Adobe Reader XI (11.0.17, Pro and Standard) for Windows is available here: https://www.adobe.com/support/downloads/detail.jsp?ftpID=6082 Reader DC and other versions are available here: https://www.adobe.com/support/downloads/product.jsp?product=10&platform=Windows Acrobat for Windows update is available here: http://www.adobe.com/support/downloads/product.jsp?product=1&platform=Windows Note: UNcheck any pre-checked additional options presented with the update. They are not part of the software update and are completely optional. Release Notes | Acrobat, Reader Security Bulletin 1 Quote Link to comment Share on other sites More sharing options...
