New GIMP Isn't Showing Up
15 replies to this topic
#1 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 25 March 2004 - 11:34 PM
I updated slackware-current tonight using swaret and the list showed the gimp 2.0 final. So it ran installed etc etc everything normally, but the new gimp doesn't seem to be here  <_< Both links in the menu open up GIMP pre4. I ran swaret again and the dropline updater to see if swaret didn't install it or something and they both said that my system was up to date.  :hmm: Where did it go? :o Thanks everyone
#2 OFFLINE   havnblast
havnblast
  • 4,878 posts
Posted 25 March 2004 - 11:41 PM
try a where is gimp or search?  should be in where the rest of files go /usr/bin/  no?
#3 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 26 March 2004 - 12:02 AM
whereis gimp shows the 1.3 directory and /usr/bin/gimp opens gimp 2 pre4 <_<
#4 OFFLINE   Bruno
Bruno
    Le Professeur Pingouin
  • Admin Emeritus
  • 37,904 posts
Posted 26 March 2004 - 05:42 AM
Hi SonicAre you sure your swaret.conf is still set to current . . . and are you using the nluug mirror ?? Because I am in Slack right now and Help --> About shows "Gimp 2.0.0" . . . . . ( By the way . . a very cool splash )Maybe uninstall ( remove ) The Gimp and download/install it again, only using swaret ? ( I don't use dropline, maybe that one "downgraded" it to pre-4 ? <_< Bruno
#5 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 26 March 2004 - 11:08 PM
ut oh. i tried that and now gimp doesn't open at all  >_<
$ gimpgimp: relocation error: gimp: undefined symbol: gdk_threads_lock
#6 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 27 March 2004 - 06:06 AM
Hi SonicWhat happens if you type the following in a terminal:
gimp-remote-2.0
:) Bruno
#7 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 27 March 2004 - 11:11 AM
If i type gimp and hit tab, it shows all the gimp commands, one of which is the one that u just gave me, and the other relating to 2.0 being 'gimp-2.0'.However, both give me the same error. How strange  :)
#8 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 27 March 2004 - 11:15 AM
I tried uninstalling gimp via swaret and then via installpkg and removed it totally... (i think :) ). However, if i reinstall the new gimp with swaret, i still get the same error.
#9 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 27 March 2004 - 02:06 PM
Hi SonicAnd a separate dependency check ? "swaret --dep" ? . . . This is a funny problem . . :) Bruno
#10 OFFLINE   jodef
jodef
    Multithreader
  • 1,429 posts
Posted 27 March 2004 - 02:23 PM
Sonic I am not sure this would cause your problem but did you purge the /var/swaret folder from what I have read uninstalling package wouldn't remove it from that folder the next time you try to install swaret might just be using the same bad pkg it finds in /var/swaret instead of redownloading.Check the /var/swaret folder to see if it refers to the gimp package and delete it and then try reinstalling.Just my thoughts.Hope you find a solution. :)
#11 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 27 March 2004 - 02:40 PM
I deleted the gimp-2.0 package from /var/swaret, ran 'swaret --remove gimp' again and then reinstalled the new gimp 2.0 package. I then ran 'swaret --dep' and am still getting the same error.This is truely strange!
#12 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 27 March 2004 - 02:48 PM
SonicCheck your /var/swaret also after "swaret --remove gimp" . . . .and clear out: /var/log/removed_packages and /var/log/removed_scripts.Then try again . . . :blink: Bruno
#13 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 27 March 2004 - 04:04 PM
YAY!I did that, and downloaded the .tgz from linuxpackages.net and manually installed it using installpkg and it worked without a problem!Thanks everyone!(And yes, it's a very cool splash :blink:)
#14 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 27 March 2004 - 04:06 PM
YES !! Hurray !! Congrats Sonic !! . . . . Finally the Gimp 2.0 ! . . . . YES !!( funny about the splash is that PCLOs has 2.0 too . . but the splash is different . . the one in Slack is nicer :blink: )B) Bruno
#15 OFFLINE   jodef
jodef
    Multithreader
  • 1,429 posts
Posted 27 March 2004 - 04:15 PM
Glad it works!!Now you're tempting me to reinstall Slack.
#16 OFFLINE   SonicDragon
SonicDragon
  • 4,188 posts
Posted 27 March 2004 - 04:38 PM
Who me? Never! :blink:  B) :o
