mounting cdrom
16 replies to this topic
#1 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 10:30 AM
Hi all!When I go into storage media ( in mandy ) and right click on the cdrom and choose "mount" I am told the "feature is available only under HAL". So I checked to make sure it was installed and it was but there were some lib files that were not. So I installed them and I still get the same message. So I tried Bruno's tip for mounting and I got the following:
[rejean@localhost ~]$ cat /etc/fstab/dev/hda2 / ext3 relatime 1 1/dev/hda6 /home ext3 relatime 1 2/dev/cdrom /media/cdrom auto umask=0022,users,iocharset=utf8,noauto,ro,exec 0 0/dev/cdrom2 /media/cdrom2 auto umask=0022,users,iocharset=utf8,noauto,ro,exec 0 0//rejean/Application\040Data /mnt/Application-Data smbfs username=% 0 0//rejean/C /mnt/C smbfs username=% 0 0//rejean/computer /mnt/computer smbfs username=% 0 0//rejean/rejean /mnt/rejean smbfs username=% 0 0/dev/hda1 /mnt/windows ntfs umask=0022,nls=utf8,ro 0 0none /proc proc defaults 0 0/dev/hda5 swap swap defaults 0 0/dev/hdb6 swap swap defaults 0 0#/dev/hda11 /mnt/storage fat 32 defaults 1 2/dev/hda11 /mnt/storage vfat rw,users,umask=000   0 0[rejean@localhost ~]$[rejean@localhost ~]$ suPassword:[root@localhost rejean]# mount /dev/cdrom[mntent]: warning: no final newline at the end of /etc/fstabmount: you must specify the filesystem type[root@localhost rejean]#
So what should be the proper code?
registered linux user #374889
#2 OFFLINE   Bruno
Bruno
    Le Professeur Pingouin
  • Admin Emeritus
  • 37,904 posts
Posted 02 September 2008 - 01:01 PM
Hi RéjeanNormally the proper command would be:
# mount /media/cdrom
  . . . BUT . . . depending if it is a data CD or a music CD in Mandriva you should automatically get a pop-up 10 to 20 seconds after inserting the CD. That pop-up will ask you what to do with the CD.If you do NOT get the pop-up it can mean 2 things: Either you had the pop-up before and ticked the box to always automatically execute one of the choices given and not show the pop-up for that kind of media again. OR . . . the CD/DVD is faulty and HAL/Mandiva can not do anything with it.:unsure: Bruno
#3 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 01:39 PM
View PostBruno, on Sep 2 2008, 01:01 PM, said:
Hi RéjeanNormally the proper command would be: "# mount /media/cdrom/"  . . . BUT . . . depending if it is a data CD or a music CD in Mandriva you should automatically get a pop-up 10 to 20 seconds after inserting the CD. That pop-up will ask you what to do with the CD.If you do NOT get the pop-up it can mean 2 things: Either you had the pop-up before and ticked the box to always automatically execute one of the choices given and not show the pop-up for that kind of media again.
Hi Bruno! I do not recall doing such a thing.[
I thought about that and should have said that I had tried several ( good ) data and music cds but none work. Even some commercial music cds but I do not get any pop-up.As for the cd that I was talkingt about it contained 3 downloads; Spybot, Ad-aware and Windows anti-spyware. I just wanted to email my sister-in-law and attach ad-aware. I rebooted into WinXP on the same machine and it worked fine. Maybe I'll try another linux distro when I have time.Finally I tried:
[rejean@localhost ~]$ suPassword:[root@localhost rejean]# mount /media/cdrom[mntent]: warning: no final newline at the end of /etc/fstabmount: you must specify the filesystem type[root@localhost rejean]# mount /media/cdrom2[mntent]: warning: no final newline at the end of /etc/fstabmount: you must specify the filesystem type[root@localhost rejean]#
with the result you can see. Any idea anyone.
#4 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 02 September 2008 - 02:03 PM
Let's see if everything is coorectly set up . . . let me see:
# dmesg | grep CD
and
# ls -al /dev/cdrom# ls -al /dev/cdrom2
BTW: Which of the 2 CD devices are you using ?:unsure: Bruno
#5 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 02:39 PM
I have a dvd burner and a dvd player but I am pretty sure that I unhooked the player because I can burn dvds so I would say it is cdrom.Here you go:
[rejean@localhost ~]$ suPassword:[root@localhost rejean]# dmesg | grep CDACPI: DSDT 7FFB0450, 5319 (r1  4CDS2 4CDS2141	  141 INTL  2002026)hdc: _NEC DVD_RW ND-1300A, ATAPI CD/DVD-ROM drivehdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)Uniform CD-ROM driver Revision: 3.20[root@localhost rejean]# ls -al /dev/cdromls: cannot access /dev/cdrom: No such file or directory[root@localhost rejean]# ls -al /dev/cdrom2ls: cannot access /dev/cdrom2: No such file or directory[root@localhost rejean]#
with of course a cd into the dvd burner.
Edited by réjean, 02 September 2008 - 02:40 PM.
#6 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 02 September 2008 - 02:41 PM
Okay Réjean . . . please test this:
# mount /dev/hdc /media/cdrom
:unsure: Bruno
#7 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 02:58 PM
We are making progress:
[root@localhost rejean]# mount /dev/hdc /media/cdrommount: block device /dev/hdc is write-protected, mounting read-only[root@localhost rejean]#
#8 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 02 September 2008 - 03:02 PM
Goooood . . . . it is mounted ( read only but that is normal behavior )Now change the fstab: these 2 lines:
to just one line:
/dev/hdc /media/cdrom auto umask=0022,users,iocharset=utf8,noauto,ro,exec 0 0
Next reboot and see if you get the popup when inserting a CD ( if not  mount it manually like we did above and you can access it ):unsure: Bruno
#9 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 04:03 PM
Great Bruno!We are making real progress. However after rebooting I tried a commercial music CD and got the following:
[rejean@localhost ~]$ suPassword:[root@localhost rejean]# mount /dev/hdc /media/cdrommount: you must specify the filesystem type
So I took the CD out and put the one I started the thread with and got this:
with:
[root@localhost rejean]# ls -al /dev/hdc /media/cdrombrw-rw---- 1 rejean cdwriter 22, 0 2008-09-02 16:56 /dev/hdc/media/cdrom:total 14dr-xr-xr-x 1 root root 2048 2005-11-09 11:51 ./drwxr-xr-x 5 root root 4096 2008-08-03 19:41 ../dr-xr-xr-x 1 root root 2048 2005-11-09 11:51 Lavasoft/dr-xr-xr-x 1 root root 4096 2005-11-09 11:51 Microsoft AntiSpyware/dr-xr-xr-x 1 root root 2048 2005-11-09 11:51 Spybot - Search & Destroy 1.1/[root@localhost rejean]#
#10 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 02 September 2008 - 04:52 PM
That's good !!And BTW: you do not ( can not ) mount music CDs . . . you just play them in KsCD of AmarokB) Bruno
#11 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 02 September 2008 - 05:02 PM
Got you!BTW I think they should have a special entry for the Nobel prize as "genius" and I would be voting for you every year until you get the prize.
#12 OFFLINE   SueD
SueD
    Posting Prodigy
  • 2,476 posts
Posted 02 September 2008 - 06:08 PM
Me too! Bruno's really good at getting our rear ends out of the fire, isn't he?
Sue
Registered Linux User #433538
A life? Cool! Where can I download one of those?
#13 OFFLINE   zlim
zlim
    It's me, plodr
  • 7,168 posts
Posted 02 September 2008 - 10:46 PM
If it weren't for Bruno and teacher, I would never have looked at linux!!! Yet alone try and actually install and use it.Posted ImageTo Bruno: for kind and tireless support to Linux New Explorers and perennial New Explorers (that would be me!)
Liz
#14 OFFLINE   jolphil
jolphil
    Message Mogul
  • PipPipPipPipPip
  • 369 posts
Posted 03 September 2008 - 08:07 AM
I still am amazed how one person knows sooo much.. :hysterical: jolphil
#15 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 03 September 2008 - 01:06 PM
LOL . . . makes me wonder what tux I should wear . . would my usual penguin outfit do or should I get my tuxedo from the dry-cleaners ?   :hysterical: :whistling: Bruno
#16 OFFLINE   réjean
réjean
  • 4,474 posts
Posted 03 September 2008 - 03:02 PM
Here is how I picture you in Stockholm Brunohttp://www.wallpaper..._serialNumber=2and forget the protocole...
Edited by réjean, 03 September 2008 - 03:03 PM.
#17 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 03 September 2008 - 04:49 PM
:hysterical:  . . . LOLB) Bruno
