SueD Posted May 19, 2007 Share Posted May 19, 2007 I got me a new video card and gosh-darn-it-all, after installing it and booted into PCLos, no KDE! There was nothing but text and I had to sign in. Fine, signed in, entered my password, tried to startx when I got the following message... Fatal Server Error:no screens foundXIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0" after 0 requests (0 known processed) with 0 events remaining.What did I do wrong? Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 19, 2007 Share Posted May 19, 2007 Of course, Sue. Your PCLinuxOS operating system was set up to operate with the hardware that you had previously set it up on. If you change that hardware, you need to let the operating system know, too. Otherwise, things go kerflooey, as you are noticing. What type of video card did you install? Quote Link to comment Share on other sites More sharing options...
SueD Posted May 19, 2007 Author Share Posted May 19, 2007 But why don't I have to tell Slackware about the new hardware? So how do I go about telling PCLos that something's changed?I bought a GeForce 6200. Quote Link to comment Share on other sites More sharing options...
striker Posted May 19, 2007 Share Posted May 19, 2007 Hi Sue,See this:http://www.brunolinux.com/06-Fine_Tuning_Y...ng_XFdrake.htmland if necessary this one:http://www.brunolinux.com/10-General_Info/...Runlevel_3.htmlBTW: Is the new card an ATI ? Just curious, I'm a nvidia fan and thought you posted somewhere the new card was an ATI ; Quote Link to comment Share on other sites More sharing options...
SueD Posted May 19, 2007 Author Share Posted May 19, 2007 Thanks Striker, off to do some reading now.The new card's an nvidia. It's brand new, bought today. Heck, it even has that new video card smell to it. Quote Link to comment Share on other sites More sharing options...
striker Posted May 19, 2007 Share Posted May 19, 2007 OK, hope it will work for ya.I'm hitting the sack now.What model nvidia are you using now Sue? Quote Link to comment Share on other sites More sharing options...
SueD Posted May 19, 2007 Author Share Posted May 19, 2007 Maybe it will and maybe it won't. I vote for will.LOLG'nite Striker. Quote Link to comment Share on other sites More sharing options...
SueD Posted May 19, 2007 Author Share Posted May 19, 2007 Yes, it's back baybee! Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 19, 2007 Share Posted May 19, 2007 You were probably running generic drivers in Slackware. And Slack may be working fine with this new card, but it reality you're NOT getting accelerated graphics unless you've installed the Nvidia drivers in Slack.About the PCLos... you may have been running generics with that previous vid hardware also. The high perf Nvidia card might not like generic "vesa" type drivers. You'll probably need to install the Nvidia drivers for PCLos, too. It's not a big deal. I'm sure someone here can walk you through it. I can help you with Slack, but I'm not that familiar with the methods for PCLos.Later... Quote Link to comment Share on other sites More sharing options...
tommyj12 Posted May 19, 2007 Share Posted May 19, 2007 Hey Sue, If it is a newer card you may want to try the 100.x.x nVidia dkms package in syanptic. It works great for my Geforce 7600Gt Tommy Quote Link to comment Share on other sites More sharing options...
SueD Posted May 19, 2007 Author Share Posted May 19, 2007 Thanks Eric, I think I can figure out how to get it working in Slack but if not, I know where to find youThanks Tommy, I look into that!. Quote Link to comment Share on other sites More sharing options...
striker Posted May 20, 2007 Share Posted May 20, 2007 Any progress yet Sue ? Quote Link to comment Share on other sites More sharing options...
SueD Posted May 21, 2007 Author Share Posted May 21, 2007 Any progress yet Sue ? Thanks for asking Striker. Answer is, I'm not sure.As Tommy suggested, I installed the 100.x.x nVidia dkms package. I went into the PCC->Hardware and configured the 3D desktop effects. Then I rebooted. How do I know it's working? Quote Link to comment Share on other sites More sharing options...
tommyj12 Posted May 21, 2007 Share Posted May 21, 2007 (edited) Sue you will see the nVidia logo splash just before X starts. Also it was updated today. It will ask to restart X for you just agree so you want have to reboot. Also now under -system -configuration- hardware there will be a windows like nVidia settings Tommy Edited May 21, 2007 by tommyj12 Quote Link to comment Share on other sites More sharing options...
striker Posted May 21, 2007 Share Posted May 21, 2007 yep, just before KDE itself starts, there will be a nvidia splash screen visible, sometimes only short, sometimes a bit longer. After that KDE gets started. The nvidia screen looks similar to this:http://www.smtechnologie.com/logitheque/up...photos/1953.jpgDo a : $ glxinfo | grep rendering in a console to see if 3D is enabled. ;)You also might try the 'glxgears' command in a terminal. Look for the 3 moving gears in a separate window and watch the framerates in the console. You can quit it with CTRL + C. Quote Link to comment Share on other sites More sharing options...
SueD Posted May 21, 2007 Author Share Posted May 21, 2007 Tommy...yup, doing the updates now. I did see the splash screen briefly so that part I know is working. But I never noticed the nVidia settings. I'll take a look at those after.Striker...saw the splash screen. I supposed I expected bells and whistles too.LOL Things don't really look that different. Maybe I'm going blind!LOLglxinfo | grep rendering does show that 3D is enabled and I did see the gears, so I guess all is honky-dorey. Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 21, 2007 Share Posted May 21, 2007 I usually test whether 3D is working by playing ppracer or gl-117. Quote Link to comment Share on other sites More sharing options...
SueD Posted May 21, 2007 Author Share Posted May 21, 2007 I usually test whether 3D is working by playing ppracer or gl-117. Sounds like something my husband might enjoy. I'll get him on that right away. Quote Link to comment Share on other sites More sharing options...
striker Posted May 21, 2007 Share Posted May 21, 2007 yep Sue, you're doing OK : nvidia rolls and rocks and you have 3D rendering. Good work Sue ! Quote Link to comment Share on other sites More sharing options...
SueD Posted May 21, 2007 Author Share Posted May 21, 2007 yep Sue, you're doing OK : nvidia rolls and rocks and you have 3D rendering. Good work Sue ! Alright...thanks Striker! Quote Link to comment Share on other sites More sharing options...
striker Posted May 21, 2007 Share Posted May 21, 2007 Quote Link to comment Share on other sites More sharing options...
