Jomama Posted March 29, 2003 Share Posted March 29, 2003 There isnt an Easy Forum so I will use this one. How do create or buy, GIFs or other files to use as an Avatar. I have seen some really good ones and I wonder if there a program to make them? I know that Forums have generic ones. Thanks Quote Link to comment Share on other sites More sharing options...
havnblast Posted March 29, 2003 Share Posted March 29, 2003 I would say if you want to make your own there is a couple free graphic programs PhotPlus or Irfanview design your own and save it as a gif - just make it within 144x144 pixels.Hope that helps ya Quote Link to comment Share on other sites More sharing options...
SonicDragon Posted March 29, 2003 Share Posted March 29, 2003 if your in windows, you can also use mspaint. go to Start>Programs>Accesories>Paint and save it as a gif. You can also get there by Start>Run (or Windows Key+R) and type mspaint. If you don't want to make your own, go to www.gograph.com. That's the best clip art site i have found.Also try http://www.animationfactory.com/ for some nice moving gifs.Hope This Helps Quote Link to comment Share on other sites More sharing options...
Frank Posted March 30, 2003 Share Posted March 30, 2003 How do create or buy, GIFs or other files to use as an Avatar.Can any member use an Avatar? If so, how would I go about adding one?Thanks.Frank Quote Link to comment Share on other sites More sharing options...
Guest Paracelsus Posted March 30, 2003 Share Posted March 30, 2003 Hi Frank,You Bet!!Just go to My Controls>Personal Profile>Edit Avatar Settings. There, you can either choose from one of the Avatars in the BB library, or upload your own (which is what those with animated GIF's are doing).Explore... And have Fun!! Quote Link to comment Share on other sites More sharing options...
Frank Posted March 30, 2003 Share Posted March 30, 2003 Thanks. It worked! Quote Link to comment Share on other sites More sharing options...
Jomama Posted March 30, 2003 Author Share Posted March 30, 2003 Thanks for the info Quote Link to comment Share on other sites More sharing options...
