Capt.Crow Posted November 5, 2014 Share Posted November 5, 2014 dpkg: configuration error: /etc/dpkg/dpkg.cfg.d/architectures:1: unknown option 'foreign-architecture then there is :- Sub-process /usr/bin/dpkg returned an error code (2) I know I did this a long time ago trying to install Skype. Now I can not undo it Quote Link to comment Share on other sites More sharing options...
securitybreach Posted November 6, 2014 Share Posted November 6, 2014 Read the solution posted here and let me know if it resolves the issue: http://askubuntu.com/questions/230952/how-do-i-fix-a-unknown-configuration-key-foreign-architecture-found-in-your Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted November 6, 2014 Author Share Posted November 6, 2014 I've had a look at that . Thank you. I am running Debian 6 squeeze on this box. The easiest way to show you ,would be to take and post a snapshot. How is that done . I have tried snapshots many times but if it happens at all I can-not for the life of me find them . Quote Link to comment Share on other sites More sharing options...
securitybreach Posted November 7, 2014 Share Posted November 7, 2014 I use scrot..The syntax is simple. scrot to take a screenshot scrot -s to select a window to take a shot of scrot -d 2 to wait two seconds before taking shot .... And it all works from the Run menu. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted November 7, 2014 Share Posted November 7, 2014 I use KSnapShot works great. Settings are all right there to see and set. Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted March 14, 2015 Author Share Posted March 14, 2015 solution to unwanted architecture. Here goes :- I used the GUI to work my way down to the offending files there were two in root /etc/dpkg/dpkg.cfg.d-----Then I opened a terminal and su /root. Once there I typed in ...rm.... Then just dragged the files over from the GUI and pressed enter.. I was able to check all gone by running symantic. Did a bit of updating and at long last got a clean exit.. Probably not the cleanest way to do it .. But it worked all good . Now for gnash ... 1 Quote Link to comment Share on other sites More sharing options...
