suggestion for an old machine
réjean
Hi all! I got this message from a friend;
need a workaround for an old dell 3200 which refuses to boot usb drives...optical drive doesn't recognize DVDRW's..hoping it will with R's when I get one..
He has Ubuntu on another machine so I am thinking of a iso that could be burnt on a CD. I do have tons of old distros I could give him. What would be a good one?
Since I posted I received the following;
thanx...but I will try a DVDR...some at Cape North...
lots of events in this..for brothers pc at first..np installing..but machine has no memory..so wanted to do on old workhorse...which then I had to replace CMOS BATTERY TWICE..HELPS TO TAKE STICKER OFF FIRST
Edited by réjean
Anti-X, derived from Mepis/Debian specifically for old machines that won't boot modern distros.
Fits on a CD-R.
Your machine probably doesn't have a DVD-RW, maybe a DVD-ROM if you are lucky.
Should boot from a CD-R.
If it will boot from a CD-R, you could use an openSuSE network install, which when I installed 13.1 on an 11-year-old Dell only required an iso burned to the cd to start the install--all software is downloaded from SuSE's servers. You'd have to use xfce or ice wm on an old machine, but either works fine on my old Dell.
Good suggestion both. It sounds his DVD player seems to be working on and off so a net install would be better no doubt. I'll see what he has to say tomorrow.
MX-14 would also be a good choice if it boots from CD. 696MB.
I have seen a problem on several very old computers where MX-14 (and pretty much every other modern distro) would not boot. I will try to remember the message. It was definitely some aspect of the pre-loader or OS is not supported on the hardware.
Here is a nice list of distros for older machines:
http://distrowatch.c...y=Old Computers
This one sounds fun
Tiny Core Linux is a 12 MB graphical Linux desktop. It is based on a recent Linux kernel, BusyBox, Tiny X, Fltk, and Flwm. The core runs entirely in memory and boots very quickly. The user has complete control over which applications and/or additional hardware to have supported, be it for a desktop, a nettop, an appliance or server; selectable from the project's online repository
http://distrowatch.com/tinycore
Sounds like he needs the Plop Boot Manager ...http://www.plop.at/e...r/download.html
It is a small ISO that you burn to a CD and when you boot from it, it magically makes the computer be able to boot from the USB.
If you are talking about the Dell with the Athlon 64 3200+, it should run most Linux distros ok if you can get a little extra RAM.
I would recommend MX-14, just because I'm a huge Xfce fan and it works great on everything I've tried it on. Or SolydX, another good distro with Xfce.
If he can change the battery, :D he should be able to blow the dust bunnies out and put a stick of RAM in.
I always pop the battery out first, and then go, Which side was the top?
Thanks everyone. I'll pass your suggestions along and hope he can get is machine (or his brother's) working. I'll definitely try Tiny Core this evening. It looks very cool.
