Browsing the Filesystem
Linux File Hierarchy Concepts
  • Files and Directories are organized into a single rooted inverted tree structure, including distinct physical volumes such as Floppy Disks, CD-ROMs and Multiple Hard Drives.
  • Filesystem begins at the root directory, represented by lonely forward slash (/).
  • Names in Linux File Hierarchy are case sensitive.
  • Paths are delimited by / such as /usr/share/bin/X11/X
  • Each shell and system process has a current working directory.
  • . refers to the current working directory.
  • .. refers to the parent directory of any particular directory - just one level up in the file hierarchy.
  • Files and Directories whose name begin with a . are hidden.
  • A user’s path is a list of directories that are searched for commands typed at the command line.
Some Important Directories
  • Home Directories: /root, /home/username
  • User Executables: /bin, /usr/bin, /usr/local/bin
  • System Executables: /sbin, /usr/sbin, /usr/local/sbin
  • Shared Libraries: /lib, /usr/lib, /usr/local/lib
  • Kernels & Boot-loaders: /boot
  • Configuration Files: /etc
  • Device Files: /dev
  • Temporary Files: /tmp
  • Other Mount-points: /media, /mnt
  • Server Data: /var, /srv
  • System Informations: /proc, /sys0
  • Optional Applications: /opt
1. Home Directories
  • Every user has a home directory.
  • The root user’s home directory is /root.
  • Most non-root user’s home directories are in /home/username...........
https://miteshshah.g...the-filesystem/
