WinXP system restore
ibe98765
I'm sure you can use the Task Scheduler to do that for you, although my personal preference is to have the Task Scheduler service disabled and to set restore points manually before any software installs. Be aware that System Restore is no replacement for a good back-up strategy using third-party software like Retrospect 6.0 from Dantz Development.Edited to add -- System Restore will automatically set a restore point at least daily if you have Task Scheduler service set to automatic, have System restore enabled, and have your computer on most of the time.
