Robert Posted August 2, 2015 Share Posted August 2, 2015 After doing a clean install of Windows 10 it is blocking the install of the video editing software. I've tried running as administrator and installing an old certificate, but nothing has worked so far. Is there a way to unblock this? Quote Link to comment Share on other sites More sharing options...
zlim Posted August 2, 2015 Share Posted August 2, 2015 Looking at the chart of Cyberlink products compatible with Windows 10 http://www.cyberlink.com/stat/window10-updates-center/enu/products.jsp your version is not listed. There is a tool you can download http://www.cyberlink.com/stat/window10-updates-center/enu/index.jsp Quote Link to comment Share on other sites More sharing options...
Robert Posted August 2, 2015 Author Share Posted August 2, 2015 (edited) Thanks for the links. The compatability test worked and showed that upgrades are required. I have the suite. I had previously upgraded to PD13, but to get the rest in the suite upgraded will cost another $200. Edited August 2, 2015 by Robert Quote Link to comment Share on other sites More sharing options...
Robert Posted August 2, 2015 Author Share Posted August 2, 2015 (edited) Back to Windows 7 Edited August 2, 2015 by Robert Quote Link to comment Share on other sites More sharing options...
frapper Posted August 2, 2015 Share Posted August 2, 2015 If you'd made an image of the Windows 7 installation (i.e., Acronis True Image) before the Win 10 adventure you wouldn't have to trust MS to try getting you back. Hope it works out for you, but I'll be surprised if they aren't some glitches. Quote Link to comment Share on other sites More sharing options...
Robert Posted August 3, 2015 Author Share Posted August 3, 2015 So far the Firefox and Thunderbird icons on the taskbar had to be deleted because the addresses were changed is all I've noticed. But I have spent little time time with it. I guess I'll find out later. Quote Link to comment Share on other sites More sharing options...
