raymac46 Posted May 18, 2012 Share Posted May 18, 2012 As a long time Gnomie I have been accustomed to using Sound Juicer to rip and encode my CDs into MP3 files. However I have been bothered recently by the fact that SJ does not retrieve CD info from the Internet all that well. You put in a CD and instead of getting a track list all the titles are blank. If you try to extract a track without manually typing in the name of the song, Sound Juicer crashes. So I looked for an alternate ripper and I found a pretty good one called Asunder. It doesn't have a pretty interface and it requires you to install lame if you want MP3 files but otherwise it works very well and the CD info it retrieves is pretty accurate - even on older CDs. Asunder is in the Ubuntu repos at least, also available for Linux Mint. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 18, 2012 Share Posted May 18, 2012 Sounds neat, I may have to check it out Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 19, 2012 Share Posted May 19, 2012 Sounds neat, I may have to check it out Heh-heh! Actually, YOU were the one who recommended Asunder to me a while back. I've been using it ever since. Works like a champ! All that techie stuff is making you lose your mind. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 19, 2012 Share Posted May 19, 2012 That's great! I haven't used anything in Linux for ripping CDs since I used to use GRIP ... been gone for a bit! Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 19, 2012 Share Posted May 19, 2012 Asunder does work very well, by the way. It's a bit complicated to install in Slackware (nothing a Slacker isn't used to already, though), but a breeze to get running in Arch. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 19, 2012 Share Posted May 19, 2012 Heh-heh! Actually, YOU were the one who recommended Asunder to me a while back. I've been using it ever since. Works like a champ! All that techie stuff is making you lose your mind. Yeah, sorry I forgot I use cdparanoia so I do not deal with a gui ripper hence why I forgot that I mentioned to ya. I usually deal with encoded mp3s so it has been a long time since I had an actual bought cd to play with. Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 19, 2012 Share Posted May 19, 2012 I used Asunder for a while and it works well. In KDE I now use SoundKonverter; it rips CDs, collects CD info for tags and converts formats as well. For any stray files that don't have tags I use Easytag and it can even search for tags online for unnamed, untagged albums. Quote Link to comment Share on other sites More sharing options...
