KIS 6 $9.99 After Rebates
JerryM
You needn't worry, the forum software will automatically chop the output to fit properly :)Otherwise, use TinyURL.com or use the [ url ] tags to put "normal" text inside a link like so:[ url=http://www.tinyurl.com ]TinyURL[ /url ](Without the spaces in between the tags. I only did that for demonstrative purposes)(P.S. here's the link: http://www.compusa.com/adproducts/product_...et_Security_6_0 )
Thanks a lot. Some sites just let the URl be too long for the window. That is a pain, and I did not want to do that.Best,Jerry
Someone wanna pick me up a copy & post it to me ... I'll send you £20. :)
That sure would be a losing proposition since you have to pay $60 for it and then apply for a rebate. :) It would be nice if they would just sell it for the price it ends up.
Rebates are a real turn-off normally. If I wanted KIS I would go for this, and just wait for the rebates. However, I am using KAV with LnS and SAS so I am happy with what I have.I also use Avira Classic on my laptop, and along with Kerio 2.1.5, and SAS I don't need KIS. I'll probably kick myself in time, such as when Newegg had KAV 6 for $24.99.Regards.Jerry
