telecomguy9 Posted July 15, 2007 Share Posted July 15, 2007 I have the CPU at the following link in one of my PC's. What I can't figure out is its normal operating temp as well as its high and low temps. Can someone please help me figure this out?http://processorfinder.intel.com/Details.aspx?sSpec=SL7PM# Quote Link to comment Share on other sites More sharing options...
Peachy Posted July 16, 2007 Share Posted July 16, 2007 The specs from that page only indicate the maximum temperature the processor should be running at before it experiences a shutdown. From my experience with that generation of processor I've seen normal idle temperatures in the mid-50s to low 60s and 65 to 67 degrees for full throttle. Quote Link to comment Share on other sites More sharing options...
telecomguy9 Posted July 16, 2007 Author Share Posted July 16, 2007 Thanks for the info, Peachy. I was thinking the same thing. The interesting thing is that this CPU came only with a complete copper heatsink - no fan at all - and I find it hard to believe that it is sufficient for the processor. Weird. Quote Link to comment Share on other sites More sharing options...
b2cm Posted July 16, 2007 Share Posted July 16, 2007 Use a power supply unit with a exhaust fan underneath near the heatsink. Quote Link to comment Share on other sites More sharing options...
telecomguy9 Posted July 16, 2007 Author Share Posted July 16, 2007 I might just replace the heatsink with a full copper that has a fan, too. Thanks for your idea, tho. Quote Link to comment Share on other sites More sharing options...
telecomguy9 Posted July 17, 2007 Author Share Posted July 17, 2007 Definitely. I have some already. Quote Link to comment Share on other sites More sharing options...
goretsky Posted July 24, 2007 Share Posted July 24, 2007 Hello,Are there mounting points on your current copper heat sink for your Intel Pentium 4 3.0E GHZ SL7PM processor? If so, then all you may need to do is attach an existing fan to it, and then plug it into the CPU FAN header pins on the motherboard.Regards,Aryeh Goretsky Quote Link to comment Share on other sites More sharing options...
telecomguy9 Posted July 24, 2007 Author Share Posted July 24, 2007 I thought about that as well, but there aren't mounting points on it. Thanks for the suggestion, though. Quote Link to comment Share on other sites More sharing options...
