réjean Posted October 18, 2005 Share Posted October 18, 2005 (edited) Hi all!Last night I decided to upgrade my pclos and it went pretty well but when I checked on it this morning I had a few error messages ( which are included in the code following ). So I recalled the thread Dale started where Bruno suggested to open synaptic and search for the kernel. The thing is that my synaptic has been broken for awhile ( I used kpackage last night to upgrade ). So I decided to uninstall synaptic and reinstall it. I had no problem uninstalling but when I tried " apt-get install synaptic " I got the following message: [rejean@localhost rejean]$ suPassword:[root@localhost rejean]# apt-get install synapticReading Package Lists... DoneBuilding Dependency Tree... Done[b]You might want to run `apt-get -f install' to correct these:The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is to be installed[/b] synaptic: Depends: pango (>= 1.8.1) but 1.4.0-1tex is to be installed Depends: libpango1.0_0 (>= 1.8.1) but 1.4.0-1tex is to be installed Depends: libatk1.0_0 (>= 1.9.1) but 1.6.0-1tex is to be installed Depends: libglade2.0_0 (>= 2.4.2) but 2.3.6-1.tex is to be installed Depends: libgtk+2.0_0 (>= 2.6.4) but 2.4.0-2tex is to be installed Depends: gtk+2.0 (>= 2.6.4) but 2.4.0-2tex is to be installed Depends: libglib2.0_0 (>= 2.6.3) but 2.4.0-1tex is to be installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).[root@localhost rejean]# the text I highlighted is the same one I got after upgrading. Should I go ahead and "apt-get -f install " all the files one by one? And should I, for example, install pango 1.4.0-1tex first and then pango 1.8.1-1 tex or 1.8.1 only, and if so how can I find out if it is pango-1.8.1-1tex or pango-1.8.1-0tex, etc.?I will wait for some wise advice before I do anything.Thanks!P.S. Sorry, I cannot highlight it but it's the few lines between the two ""s. Edited October 18, 2005 by réjean Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Ok! I just tried a few to see what would happen: [root@localhost rejean]# apt-get -f install pango1.4.0-1texReading Package Lists... DoneBuilding Dependency Tree... DoneE: Couldn't find package pango1.4.0-1tex[root@localhost rejean]# apt-get -f install libpango1.4.0-1texReading Package Lists... DoneBuilding Dependency Tree... DoneE: Couldn't find package libpango1.4.0-1tex[root@localhost rejean]# Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 18, 2005 Share Posted October 18, 2005 # apt-get update Make sure your package lists are up to date. It may also be that the server is being updated now too. Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Thanks Ross. The server must be being updated: [root@localhost rejean]# apt-get updateIgn http://ftp.ibiblio.org pclinuxos/2004 releaseGet:1 ftp://ftp.nluug.nl pclinuxos/2004 release [1405B]Get:2 ftp://ftp.gwdg.de pclinuxos/2004 releaseIgn ftp://ftp.gwdg.de pclinuxos/2004 releaseGet:3 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004 releaseIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004 releaseFetched 1405B in 4s (349B/s)Err http://ftp.ibiblio.org pclinuxos/2004/os pkglist 301 Moved PermanentlyGet:1 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os pkglistErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os pkglist Unable to fetch file, server said 'Failed to open file. 'Get:2 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os releaseGet:3 ftp://ftp.gwdg.de pclinuxos/2004/os pkglistIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os releaseHit ftp://ftp.nluug.nl pclinuxos/2004/os pkglistGet:4 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates pkglistHit ftp://ftp.nluug.nl pclinuxos/2004/os releaseErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates pkglist Unable to fetch file, server said 'Failed to open file. 'Err ftp://ftp.gwdg.de pclinuxos/2004/os pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os.bz2: No such file or directory. 'Get:5 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates releaseHit ftp://ftp.nluug.nl pclinuxos/2004/updates pkglistGet:6 ftp://ftp.gwdg.de pclinuxos/2004/os releaseIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates releaseHit ftp://ftp.nluug.nl pclinuxos/2004/updates releaseGet:7 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar pkglistIgn ftp://ftp.gwdg.de pclinuxos/2004/os releaseHit ftp://ftp.nluug.nl pclinuxos/2004/texstar pkglistGet:8 ftp://ftp.gwdg.de pclinuxos/2004/updates pkglistHit ftp://ftp.nluug.nl pclinuxos/2004/texstar releaseErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar pkglist Unable to fetch file, server said 'Failed to open file. 'Get:9 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar releaseErr ftp://ftp.gwdg.de pclinuxos/2004/updates pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates.bz2: No such file or directory. 'Ign ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar releaseGet:10 ftp://ftp.gwdg.de pclinuxos/2004/updates releaseIgn http://ftp.ibiblio.org pclinuxos/2004/os releaseIgn ftp://ftp.gwdg.de pclinuxos/2004/updates releaseGet:11 ftp://ftp.gwdg.de pclinuxos/2004/texstar pkglistErr ftp://ftp.gwdg.de pclinuxos/2004/texstar pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar.bz2: No such file or directory. 'Get:12 ftp://ftp.gwdg.de pclinuxos/2004/texstar releaseIgn ftp://ftp.gwdg.de pclinuxos/2004/texstar releaseErr http://ftp.ibiblio.org pclinuxos/2004/updates pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/updates releaseErr http://ftp.ibiblio.org pclinuxos/2004/texstar pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/texstar releaseFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar 301 Moved PermanentlyFailed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os.bz2: No such file or directory. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates.bz2: No such file or directory. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar.bz2: No such file or directory. 'Reading Package Lists... DoneBuilding Dependency Tree... DoneE: Some index files failed to download, they have been ignored, or old ones used instead.[root@localhost rejean]# Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Hi RéjeanHow come all those different mirrors are active ?? . . . Looks like you get lists from everywhere around the world . . . Anyway . . . could you try "apt-get update" now ?? . . . And please do not use Kpackage anymore and see to it that you can use Synaptic a.s.a.p. ! Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Hi Bruno! [root@localhost rejean]# apt-get updateGet:1 ftp://ftp.nluug.nl pclinuxos/2004 release [1405B]Get:2 ftp://ftp.gwdg.de pclinuxos/2004 releaseIgn ftp://ftp.gwdg.de pclinuxos/2004 releaseGet:3 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004 releaseIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004 releaseIgn http://ftp.ibiblio.org pclinuxos/2004 releaseFetched 1405B in 3s (417B/s)Err http://ftp.ibiblio.org pclinuxos/2004/os pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/os releaseErr http://ftp.ibiblio.org pclinuxos/2004/updates pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/updates releaseGet:1 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os pkglistErr http://ftp.ibiblio.org pclinuxos/2004/texstar pkglist 301 Moved PermanentlyErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os pkglist Unable to fetch file, server said 'Failed to open file. 'Ign http://ftp.ibiblio.org pclinuxos/2004/texstar releaseHit ftp://ftp.nluug.nl pclinuxos/2004/os pkglistGet:2 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os releaseIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/os releaseHit ftp://ftp.nluug.nl pclinuxos/2004/os releaseGet:3 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates pkglistHit ftp://ftp.nluug.nl pclinuxos/2004/updates pkglistErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates pkglist Unable to fetch file, server said 'Failed to open file. 'Hit ftp://ftp.nluug.nl pclinuxos/2004/updates releaseGet:4 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates releaseHit ftp://ftp.nluug.nl pclinuxos/2004/texstar pkglistIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/updates releaseGet:5 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar pkglistHit ftp://ftp.nluug.nl pclinuxos/2004/texstar releaseErr ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar pkglist Unable to fetch file, server said 'Failed to open file. 'Get:6 ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar releaseIgn ftp://ftp-linux.cc.gatech.edu pclinuxos/2004/texstar releaseGet:7 ftp://ftp.gwdg.de pclinuxos/2004/os pkglistErr ftp://ftp.gwdg.de pclinuxos/2004/os pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os.bz2: No such file or directory. 'Get:8 ftp://ftp.gwdg.de pclinuxos/2004/os releaseIgn ftp://ftp.gwdg.de pclinuxos/2004/os releaseGet:9 ftp://ftp.gwdg.de pclinuxos/2004/updates pkglistErr ftp://ftp.gwdg.de pclinuxos/2004/updates pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates.bz2: No such file or directory. 'Get:10 ftp://ftp.gwdg.de pclinuxos/2004/updates releaseIgn ftp://ftp.gwdg.de pclinuxos/2004/updates releaseGet:11 ftp://ftp.gwdg.de pclinuxos/2004/texstar pkglistErr ftp://ftp.gwdg.de pclinuxos/2004/texstar pkglist Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar.bz2: No such file or directory. 'Get:12 ftp://ftp.gwdg.de pclinuxos/2004/texstar releaseIgn ftp://ftp.gwdg.de pclinuxos/2004/texstar releaseFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar 301 Moved PermanentlyFailed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar Unable to fetch file, server said 'Failed to open file. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os.bz2: No such file or directory. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates.bz2: No such file or directory. 'Failed to fetch ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar Unable to fetch file, server said '/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar.bz2: No such file or directory. 'Reading Package Lists... DoneBuilding Dependency Tree... DoneE: Some index files failed to download, they have been ignored, or old ones used instead.[root@localhost rejean]# Should I try "apt-get update now"? Or maybe "apt-get update I'm in a hurry" lol.Seriously I wouldn't have used kpackage if Synaptic had been working. Anything else I can try from a console because I've tried kynaptic and same thing, no go. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Sorry . . I was meaning to say: "apt-get upgrade" . . . LOL . . you already had done the "update" . . . My mistake :PB) Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Hi Bruno!I did the upgrade last night ( over night ) and here is what I found this morning: [root@localhost rejean]# apt-get upgradeReading Package Lists... DoneBuilding Dependency Tree... DoneYou might want to run `apt-get -f install' to correct these.The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try using -f.[root@localhost rejean]# This is why I tried updating as Ross suggested. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 kernel-pclos-2.6.11.oci3.mdk#1-1ociBut that is the wrong kernel . . . :(Could you first please show us # cat /etc/apt/sources.list Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 I did noticed in Dale's thread that you had mentionned kernel-pclos-2.6.11.oci4.mdk#1-1oci root@localhost rejean]# cat /etc/apt/sources.list#PCLINUXOS apt repositoryrpm http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstarrpm ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstarrpm ftp://ftp.nluug.nl/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstarrpm ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstar but I couldn't refresh my list in kpackage and didn't know how to do it in console mode. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Hi RéjeanYou will need to comment out a few sources !!Look here: #PCLINUXOS apt repositoryrpm http://ftp.ibiblio.org/pub/Linux/distribut.../pclinuxos/apt/ pclinuxos/2004 os updates texstar# rpm ftp://ftp-linux.cc.gatech.edu/pub/metalab.../pclinuxos/apt/ pclinuxos/2004 os updates texstar# rpm ftp://ftp.nluug.nl/pub/metalab/distributi.../pclinuxos/apt/ pclinuxos/2004 os updates texstar# rpm ftp://ftp.gwdg.de/pub/linux/mirrors/sunsi.../pclinuxos/apt/ pclinuxos/2004 os updates texstarThen do "apt-get update" again . . . . and let me see what it says . . Bruno Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 18, 2005 Share Posted October 18, 2005 Yes, indeed. Too many sources, and I can guarantee that they are not all in sync!They are supposed to mirror each other, but that does not happen all the time. You will only want to have one source active at all times. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 PART 2 I did noticed in Dale's thread that you had mentionned kernel-pclos-2.6.11.oci4.mdk#1-1ociNope . . . the 2.6.12.oci4 . . . but please the correct one . . . First we need to know # uname -r After that we get the new kernel with one of these 4: # apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1tex# apt-get install kernel-pclos-i586-up-1GB-2.6.12.oci4.mdk#1-1tex# apt-get install kernel-pclos-i586-up-4GB-2.6.12.oci4.mdk#1-1tex# apt-get install kernel-pclos-smp-2.6.12.oci4.mdk#1-1tex BUT . . only ONE of them . . . . . . !!!! . . The one that matches the "uname -r" . . . .later you can remove the old kernel in Synaptic. Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 (edited) here: [root@localhost rejean]# uname -r2.4.22-32tex[root@localhost rejean]# I could probably go by process of elimination . knowing that all I've got is 320 or so MB of RAM but I'll wait for you! Now hurry up I've got a bus to catch. Just kidding!!!lol! I do appreciate your help Bruno, you know that! Edited October 18, 2005 by réjean Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 # apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1tex This is the one . . . . BUT . . did you comment out the sources like I indicated 4 posts up ? ( if not please do that first ) BrunoPS: After the kernel upgrade you will see a new section in Lilo "-2.6.12.oci4" . . that is the one you should boot from now on. Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Hi Bruno!How and where would I comment them out. If I were in Mandriva or somewhere else, Suse for example I would know but since synatic is not working I haven't got a clue. A hint?...please, pretty please. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Hi RéjeanYou simply do # kwrite /etc/apt/sources.list And the file will open in the editor . . . then you place the # marks and save the file.After that you do # apt-get update# apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1tex Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Almost there people: [root@localhost rejean]# apt-get updateIgn http://ftp.ibiblio.org pclinuxos/2004 releaseErr http://ftp.ibiblio.org pclinuxos/2004/os pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/os releaseErr http://ftp.ibiblio.org pclinuxos/2004/updates pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/updates releaseErr http://ftp.ibiblio.org pclinuxos/2004/texstar pkglist 301 Moved PermanentlyIgn http://ftp.ibiblio.org pclinuxos/2004/texstar releaseFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.os 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.updates 301 Moved PermanentlyFailed to fetch http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/pclinuxos/2004/base/pkglist.texstar 301 Moved PermanentlyReading Package Lists... DoneBuilding Dependency Tree... DoneE: Some index files failed to download, they have been ignored, or old ones used instead.[root@localhost rejean]# apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1texReading Package Lists... DoneBuilding Dependency Tree... DoneE: Couldn't find package kernel-pclos-2.6.12.oci4.mdk#1-1tex[root@localhost rejean]# and my /etc/apt/sources.list: [root@localhost rejean]# cat /etc/apt/sources.list#PCLINUXOS apt repositoryrpm http://ftp.ibiblio.org/pub/Linux/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstar#rpm ftp://ftp-linux.cc.gatech.edu/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates #texstar#rpm ftp://ftp.nluug.nl/pub/metalab/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstar#rpm ftp://ftp.gwdg.de/pub/linux/mirrors/sunsite/distributions/contrib/texstar/pclinuxos/apt/ pclinuxos/2004 os updates #texstar[root@localhost rejean]# Quote Link to comment Share on other sites More sharing options...
teacher Posted October 18, 2005 Share Posted October 18, 2005 RejeanYou have an error in your sources list. You need to take out the space between the "apt/" and the "pclinuxos". You can not have a space there. That is why you had the error messages. Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 18, 2005 Share Posted October 18, 2005 rpm ftp://distro.ibiblio.org/pub/linux/distributions/texstar/pclinuxos/apt/ pclinuxos/2004 os updates texstar This is in my sources.list file... and it works. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 RejeanYou have an error in your sources list. You need to take out the space between the "apt/" and the "pclinuxos". You can not have a space there. That is why you had the error messages. Sorry Teach . . I have a space there too . . . and it works for me . . . . ( Adam has them there also )Réjean had errors because he had all 4 sources "active" Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 (edited) Ok! We are making some progress people, move it, move it. lol! Seriously I tried Julia's suggestion first and that wasn't enough. Then I tried adding Ross' source and commenting out the first source ( the one Julia asked me to fix ) then bingo: [root@localhost rejean]# apt-get updateGet:1 ftp://distro.ibiblio.org pclinuxos/2004 release [1576B]Fetched 1576B in 1s (1167B/s)Get:1 ftp://distro.ibiblio.org pclinuxos/2004/os pkglist [506kB]Get:2 ftp://distro.ibiblio.org pclinuxos/2004/os release [121B]Get:3 ftp://distro.ibiblio.org pclinuxos/2004/updates pkglist [615kB]Get:4 ftp://distro.ibiblio.org pclinuxos/2004/updates release [126B]Get:5 ftp://distro.ibiblio.org pclinuxos/2004/texstar pkglist [93.5kB]Get:6 ftp://distro.ibiblio.org pclinuxos/2004/texstar release [126B]Fetched 1215kB in 19s (61.4kB/s)Reading Package Lists... DoneBuilding Dependency Tree... Done but then: [root@localhost rejean]# apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1texReading Package Lists... DoneBuilding Dependency Tree... DoneYou might want to run `apt-get -f install' to correct these:The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is to be installed kernel-pclos-2.6.12.oci4.mdk#1-1tex: Depends: module-init-tools (>= 3.0-7) but 3.0-2.1tex is to be installed Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is to be installed Depends: menu (>= 2.1.23) but 2.1.9-19tex is to be installed perl-HTML-Tagset: Depends: perl-base (>= 2:5.8.5) but 2:5.8.1-0.RC4.3mdk is to be installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).[root@localhost rejean]# So I'll try going ahead and force install the missing files, I guess. Edited October 18, 2005 by réjean Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 [root@localhost rejean]# apt-get install kernel-pclos-2.6.12.oci4.mdk#1-1texReading Package Lists... DoneBuilding Dependency Tree... DoneE: Couldn't find package kernel-pclos-2.6.12.oci4.mdk#1-1tex[root@localhost rejean]#Let me see # apt-get install kernel Bruno Quote Link to comment Share on other sites More sharing options...
teacher Posted October 18, 2005 Share Posted October 18, 2005 You are getting there. Sorry about leading you astray. I was in the middle of my Suse laptop updates when I posted. I tried with the space to get to the web site and got errors but it worked without the space. Glad you are making progress. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Please do # apt-get upgrade# apt-get check This will verify the dependencies . . . . Bruno Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 18, 2005 Share Posted October 18, 2005 do an apt-get dist-upgrade first, then do the install for the kernel. Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 Here you go Bruno: [root@localhost rejean]# apt-get install kernelReading Package Lists... DoneBuilding Dependency Tree... DonePackage kernel is a virtual package provided by: kernel-2.4.22.32tex#1-1mdk 1-1mdk kernel-pclos-2.6.11.oci3.mdk#1-1oci 1-1oci kernel-pclos-smp-2.6.12.oci5.mdk#1-1tex 1-1tex kernel-pclos-smp-2.6.12.oci4.mdk#1-1tex 1-1tex kernel-pclos-i686-up-4GB-2.6.12.oci5.mdk#1-1tex 1-1tex kernel-pclos-i686-up-4GB-2.6.12.oci4.mdk#1-1tex 1-1tex kernel-pclos-i586-up-1GB-2.6.12.oci5.mdk#1-1tex 1-1tex kernel-pclos-i586-up-1GB-2.6.12.oci4.mdk#1-1tex 1-1tex kernel-pclos-2.6.12.oci5.mdk#1-1tex 1-1tex kernel-pclos-2.6.12.oci4.mdk#1-1tex 1-1tex kernel-pclos-smp-2.6.11.oci12.mdk#1-1oci 1-1oci kernel-pclos-i686-up-4GB-2.6.11.oci12.mdk#1-1oci 1-1oci kernel-pclos-i586-up-1GB-2.6.11.oci12.mdk#1-1oci 1-1oci kernel-pclos-2.6.11.oci12.mdk#1-1oci 1-1ociYou should explicitly select one to install.E: Package kernel has no installation candidate[root@localhost rejean]# Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Goood . . .excellent . . . . now FIRST: # apt-get upgrade# apt-get check Bruno Quote Link to comment Share on other sites More sharing options...
réjean Posted October 18, 2005 Author Share Posted October 18, 2005 and here is the one for Ross: [root@localhost rejean]# apt-get dist-upgradeReading Package Lists... DoneBuilding Dependency Tree... DoneYou might want to run `apt-get -f install' to correct these.The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is installed perl-HTML-Tagset: Depends: perl-base (>= 2:5.8.5) but 2:5.8.1-0.RC4.3mdk is installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try using -f.[root@localhost rejean]# and the one for Bruno: [root@localhost rejean]# apt-get upgradeReading Package Lists... DoneBuilding Dependency Tree... DoneYou might want to run `apt-get -f install' to correct these.The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is installed perl-HTML-Tagset: Depends: perl-base (>= 2:5.8.5) but 2:5.8.1-0.RC4.3mdk is installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try using -f.[root@localhost rejean]# apt-get checkReading Package Lists... DoneBuilding Dependency Tree... DoneYou might want to run `apt-get -f install' to correct these.The following packages have unmet dependencies: cpio: PreDepends: /sbin/rmt kernel-pclos-2.6.11.oci3.mdk#1-1oci: Depends: bootloader-utils (>= 1.9) but 1.6-7.1tex is installed perl-HTML-Tagset: Depends: perl-base (>= 2:5.8.5) but 2:5.8.1-0.RC4.3mdk is installed tar: PreDepends: /sbin/rmtE: Unmet dependencies. Try using -f.[root@localhost rejean]# Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 18, 2005 Share Posted October 18, 2005 Okay now show me # apt-get -f install Maybe we have to switch mirror because this one seems not to have the latest packages . . Bruno Quote Link to comment Share on other sites More sharing options...
