crp Posted October 6, 2014 Share Posted October 6, 2014 On a Debian Wheezy box: # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/sda1 during installation UUID=ce42cdd0-80a1-4429-b84c-04cd86e77387 / ext4 errors=remount-ro 0 1 # /home was on /dev/sda10 during installation UUID=95212b8b-ec28-45a1-9c50-6e5c20c89542 /home ext4 defaults 0 2 # /tmp was on /dev/sda9 during installation UUID=c5877762-bfdb-472e-bd7a-8ef8ac2b3b3e /tmp ext4 defaults 0 2 # /usr was on /dev/sda6 during installation UUID=d1e13853-e1d3-4870-afd6-b67a539dcff3 /usr ext4 defaults 0 2 # /var was on /dev/sda7 during installation UUID=dc915949-d3a2-48ae-8c60-5547b283f9b6 /var ext4 defaults 0 2 # swap was on /dev/sda8 during installation UUID=9d9d1dc0-d81e-4ed9-9d91-0ebf7d931a57 none swap sw 0 0 /dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0 /dev/sda5 /mnt/fileshare ntfs uid=1000,nosuid,dev,noatime,gid=100,exec 0 0 /dev/sdb1 /mnt/SAC ntfs defaults 0 0 /mnt/fileshare/E /export/E bind bind 0 LABEL=part2_newHD /mnt/NewHDpart2 ext3 noatime 0 0 /mnt/NewHDpart2 /export/NewHDpart2 bind bind 0 Those 2 bind lines have me confused. The intent (i'm pretty sure) is for those directories to be NFS available to other pc's . So why are they showing up here? I think this is causing the df command to take quite a long time to run (over 2 minutes) :~14:20:44$ df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 330215 205956 107210 66% / udev 10240 0 10240 0% /dev tmpfs 388988 14092 374896 4% /run /dev/disk/by-uuid/ce42cdd0-80a1-4429-b84c-04cd86e77387 330215 205956 107210 66% / tmpfs 5120 0 5120 0% /run/lock tmpfs 2333620 232 2333388 1% /run/shm /dev/sda10 53244436 34400964 16138784 69% /home /dev/sda9 376807 10306 347045 3% /tmp /dev/sda6 8649992 3591664 4618932 44% /usr /dev/sda7 2882592 1075944 1660216 40% /var /dev/sda5 77723640 60983548 16740092 79% /mnt/fileshare /dev/sdb1 244223996 21157308 223066688 9% /mnt/SAC /dev/sda5 77723640 60983548 16740092 79% /export/E /dev/sdb2 240324580 240324580 0 100% /export/NewHDpart2 /dev/sdb2 240324580 240324580 0 100% /mnt/NewHDpart2 /dev/sr0 3904304 3904304 0 100% /media/cdrom0 :~14:23:11$ (bummer, can not use underline when in code block) Quote Link to comment Share on other sites More sharing options...
