raymac46 Posted January 28, 2016 Share Posted January 28, 2016 A friend of mine has an Acer all in one that he upgraded from Windows 7 to Windows 10. Now the latest Windows 10 November upgrade won't install (we couldn't update the system reserved partition.) I think the problem is that Windows 7 machines have only a 100 MB reserved partition and Windows 8 and 10 have 350 MB. The solution (I think) is to use a partition manager and enlarge the system reserved partition. Great. Move a 930 GB partition to get an extra 250 MB. Anybody else seen this problem? Quote Link to comment Share on other sites More sharing options...
raymac46 Posted February 5, 2016 Author Share Posted February 5, 2016 We fixed his problem by using Minitool 9 bootable Partition Wizard to expand the Reserved Partition from 100 MB to 1.5 GB. Considering we had 900 GB to play with it wasn't a big deal. Took about 5 minutes to move some files. Windows 10 booted normally and we were able to install the updates. 2 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted February 8, 2016 Share Posted February 8, 2016 Thanks for postinb back with the remedy. Quote Link to comment Share on other sites More sharing options...
