twistedcranium Posted May 24, 2003 Share Posted May 24, 2003 I'm preparing to update the kernel I'm using in RH 9 through the up2date package. I understand that after the setup I'll have two kernels installed on my machine. How do I go about removing the older kernel once I am comfy with the new one? Quote Link to comment Share on other sites More sharing options...
greengeek Posted May 24, 2003 Share Posted May 24, 2003 I think it's just a matter of deleting the binaries and source code but you better wait for more expert advice in case you stuff it up. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 25, 2003 Share Posted May 25, 2003 Hope you have a link to your new kernel in /boot. And it has a different number behind it as the old one. Then you can remove the old vmlinuz by ¨rm /boot/vmlinuz¨ ( or vmlinuz-xxx, where xxx is the number of the old kernel, but in most cases the old one does not have a number behind it )Removing it does not save that much space though, hardly 1 MB. Bruno Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 25, 2003 Share Posted May 25, 2003 I usually leave the old kernel there and add the new one to lilo (or grub is that's what you use) as a separate entry.That way if there is a problem with the new kernel for some reason, you can still boot with a known good kernel and fix the problem. Quote Link to comment Share on other sites More sharing options...
