Corrine Posted May 8, 2015 Share Posted May 8, 2015 Pale Moon has been updated to version 25.4. This is a major update which numerous fixes/changes as well as security updates. Important: If you use a language pack, make sure to update it to the latest version! Although automatic updates are enabled for language packs, double-check that the version matches. If you are using an older language pack with this version of the browser, some dialog boxes may come up blank. Security fixes: Fixed several memory safety hazards (UAF/DF/UU); applicable bugs covered by CVE-2015-0815 and CVE-2015-0815. Fixed CVE-2015-0811 [qcms] heap info leak. Fixed CVE-2015-0810 clickjacking attacks via a Flash object in conjunction with DIV elements. Fixed CVE-2015-0801 a variant of CVE-2015-0818. Fixed CVE-2015-0800 improve randomness of DNS resolver queries on Android. Fixed CVE-2015-0798 access to privileged URLs through about: redirector. See the Release Notes for the extensive list of fixes, changes and additions. 2 Quote Link to comment Share on other sites More sharing options...
Corrine Posted May 10, 2015 Author Share Posted May 10, 2015 From Pale Moon - Release Notes: This is a small but important update to the previous major release to address some critical issues: Fixed loss of the browser's disk cache on startup due to incorrect corruption detection logic Fixed a browser crash on some HTML5 games Quote Link to comment Share on other sites More sharing options...
