securitybreach Posted November 4, 2015 Share Posted November 4, 2015 Linux and UNIX system services are configured using various text files located in /etc/ or /usr/local/etc/ directory tree. A typical server system could have dozens of configuration files. It is important that you check the validity of the configuration file. In some cases it is possible to to check the sanity of the special data (such as keys) or directories (such as /var/lib/cache/). Text files are easier to manage remotely. You can use ssh and a text editor. If there is an error in configuration, server may not start. This may result into a disaster. In this article I will explains how-to find out a syntax error for popular servers and test configuration file for syntax errors. Stop! Test Your Server Configuration Before Restarting Unix / Linux Services The following option(s) will not run server (or stop running server), it will just test the configuration file and then exit. It will check configuration for correct syntax and then try to open files referred in configuration. The config file is parsed and checked for syntax errors, along with all files included config file(s) by server. In most case you can also specify which configuration file server should useinstead of the default. Once you've verified your configuration files and fixed any errors you can go ahead and reload or restart required services. A Note About Reloading Servers The syntax is as follows under Linux: /sbin/service SERVICE-NAME [reload|restart] OR /etc/init.d/SERVICE-NAME [reload|restart] OR systemctl reload SERVICE-NAME-HERE The reload option reloads the config file without interrupting pending operations. For example the following command will reload Apache web server after the config file changes: # /sbin/service httpd reload OR # systemctl reload httpd However, most Linux and Unix-like daemon programs sometimes use SIGHUP as a signalto restart themselves, the most common reason for this being to re-read a configuration file that has been changed. The syntax is as follows: kill -HUP $(cat /var/run/SERVICE.pid) OR kill -HUP `cat /var/run/SERVICE.pid` Let us see how to test the syntax for various Unix and Linux serveries.,,,,,,, http://www.cyberciti...tax-errors.html Quote Link to comment Share on other sites More sharing options...
