computer reboots randomly
83 replies to this topic
#1 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 09 July 2004 - 03:19 PM
Hello...,,,Another computer problem on a different machine. This is one I put together for resale but now it is giving me fits. I am only on dial up so I have no real way of making a web connection using the ethernet connection (it is an onboard connection). The mainboard is an ASROCK K7S8X, when I assembled it and checked it out it was fine, connectied to the web via the modem and got all the updates for the OS (about 8 hours worth) and not a problem. I used it for 3-4 days on the web and just game playing, no problems. The person that wants to buy it uses broadband (not sure if it DSL or cable) and that is where the  problem comes in. It for some reason will not  run for any great length of time without rebooting for no apparent reason. I have also noticed that the connection that is set up for the broadband does not show up when you click start>connections .. all it lists is "show all connections" (even though there is only one). I tried to set it up 3 different ways but it makes no difference, same results every time. My question is, could this be a BIOS problem (incorrect fsb settings), or maybe a loose ram stick. Those are the only two things I can think of myself. I am open to all suggestions here.
Dale
U.S. Navy (ret.) '62 - '84
Communications (Radioman)
Reg. Linux User 412421
#2 OFFLINE   epp_b
epp_b
  • 4,735 posts
Posted 09 July 2004 - 03:40 PM
Is this on WinXP?  If so, do you get a "blue screen flash" with a bunch of white text just before it reboots?  I had those once, and the cause was mainly bad RAM.
#3 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 09 July 2004 - 03:50 PM
epp_bNot really,  it is in Win XP but the last time it did it I was getting ready to run Adaware and had just clicked on the start button when it went into reboot. It never did this to me when I was using it on dial-up and I ran it for hours ... it has only happened while using it on broadband. I just brought it back and have not hooked it up to dial up yet but I was trying in on broadband and in the approx. 30-45 mins I was running it, it rebooted 4 different times. Twice it gave me that "experienced a serious error" message and wanted to send a notification to Microsoft.
Dale
#4 OFFLINE   pierrejamme
pierrejamme
    Contributor
  • PipPip
  • 12 posts
Posted 09 July 2004 - 03:52 PM
If you suspect RAM, and it is highly probably, remove all but one stick and check it out.  Check each chip to see if you can locate a bad one.  If you only have two then it will be a short test.  Does your mobo require paired ram, that will make it difficult.My home computer has four slots and it won't boot when I put my twwo chips in slot 0 and 1 as the manual says so they are in 0 and 2, Oh well.Are you sure you haven't picked up a virus?  Or a load of Spyware?If XP run msconfig and uncheck startup, then click on Services tab and select hide MS services and unselect everything else, does it still happen?Just a few thoughts late Friday, :">
#5 OFFLINE   GolfProRM
GolfProRM
    Mr. Incredible
  • 2,910 posts
Posted 09 July 2004 - 04:03 PM
I was wondering if it's not the Blaster virus or something similar...
#6 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 09 July 2004 - 04:05 PM
pierrejamme.....I could do that, I am somewhat suspect of the ram but not real set in stone on that .... I have not yet set it up to see if it will do it in dial up mode.   That is what has me totally confused .....  it did not do it before when I was using it on the dial up modem .. but it does do it when used with broadband ... I will know more after I bench test it for awhile ...  but  as you say   ram  makes for a very good suspect.One other thing that comes to mind too, at one point I had Slack 9.1 on that machine and it was fine ....  is there any such thing as an OS biased machine ???   :">  :thumbsup:
Dale
#7 OFFLINE   nlinecomputers
nlinecomputers
  • No Longer a Member
  • 3,932 posts
Posted 09 July 2004 - 04:07 PM
Microsoft has a dos based memory tester that you can download at:http://oca.microsoft.../en/windiag.aspThere is also Memtest 86 which also does a good test.http://www.memtest86.com/If this machine is running Windows XP or 2000 then errors may be logged in the event logs.  Have you checked these?
#8 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 09 July 2004 - 04:35 PM
nlinecomputers/GolfProRM .....First the event logs, ??????  how/what/where ... have never used them so I need a guiding hand there ....    As far as a virus goes  ...  I  have no idea at all ....  I have not set it up yet at my place to see .. but I did have it set up at the guys place that was selling it for me. He has cable internet but I did not (really was not looking either) for anything like that. Was more interested in trying to find out what the machine was doing wrong. After I get it set up I will check out the two links you posted. I am getting to the point  of not building anymore computers except for my own use (course this is the only one that has given me fits) ....  oh well ,,, more to come  later on
Dale
#9 OFFLINE   teacher
teacher
    Acute Mac
  • Honorary Moderators
  • 13,854 posts
Posted 09 July 2004 - 04:46 PM
Events Log:Control Panel --> Administrative Tasks --> Event Viewer!Give that a try.Julia :)
Teacher
Beach Bum Extraordinaire
#10 OFFLINE   nlinecomputers
nlinecomputers
  • 3,932 posts
Posted 09 July 2004 - 04:52 PM
This link has alot of info on the event logs:http://www.jsiinc.co...4300/rh4317.htmBasicly in Windows XP goto Start/ Control Panel/ Adminstrative Tools/ Event Viewer.  You have three event logs System, Security, and Application.  Most lilkely the events are in the system logs but they could be in application.  Look for Yellow or Red icons as they denote problems.
#11 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 01:58 PM
I am currently on this machine that does the random/at will reboots, checked the event logs like was suggested and there is enough red there (some yellow too) to qualify it for a combat zone ....most are  "system errors" dealing with either no source of accurate time, or during dns lookup of manually configured peer "time windows.com.0x1, a trememdous amount are  for catagory 102 evebt 1003 or event 10005. A lot are about cannot start this service in safe mode, a lot of yellows about the cdrom and paging of it .... I am not sure if this is user related or machine related. I have noticed that on occasion during the boot up that sometimes the  cdrom which is the secondary master gets "not detected" but it is still usable ??? ...  any  suggestions  ,, anyone ,, have  not yet done the memtest on my way now    bbl
Dale
#12 OFFLINE   Cluttermagnet
    Nocturnal Radio Geek
  • 3,877 posts
Posted 10 July 2004 - 02:13 PM
The last time I saw this symptom, it was on an old Windows machine, about 500MHz, running XP Home on an AMD processor. The owner had picked up a virus probably due to unpatched vulnerabilities in the IE browser. When first I saw any 'symptoms', there was a new desktop icon. The problem proved to be one of those 'web downloader' hacks, and I was not experienced enough to do battle with the bugs. The system went downhill rapidly, with the HD being written off as hopelessly compromised and a total wipe and reinstallation of the OS being the only practical option. Only one time have I ever seen such a compromised system, never had this sort of thing happen to any of my own machines. The giveaway, IMO, is the reboot immediately following your invoking any spyware/ security software. My bet is you have trojans on board, and who knows what else- including keystroke monitors, etc. If you can get a late copy of Hijack This and present the logs on this forum, some of the guys are good at spotting suspicious entries. Personally, if I ever concluded that I had a machine compromised in this manner, I would wipe the HD and make a fresh start.
Special Limited Edition Cluttermaster 2007 with direct air cooling system.
"ClutterLabs" --open hardware for open software" .......... Registered Linux User 446867
("It takes an entire village to raise a child...")
"It takes only one bulldozer to raze an entire village..."
"Hey, Fred- isn't that your kid driving that bulldozer?"
In loving memory of Bruno Knaapen of Amsterdam, who shared
his love of Linux, and thereby made the world a better place...
#13 OFFLINE   nlinecomputers
nlinecomputers
  • 3,932 posts
Posted 10 July 2004 - 03:04 PM
Can you post one of those "Can't start service entries?"  When you click on one of those events in the event log a window pops up that has a copy icon(looks like two sheets of paper) under two arrow icons.  If you click on that copy icon the error gets copied into the clipboard.  So you can post it here.  I like to see  service failures and the cdrom failure.  I'm guessing you got hardware problems and not a virus/malware problem but I so often see this crap on systems that a good cleaning is allways recomminded.To do a good clean up do the steps outlined here:http://aumha.org/a/quickfix.htmIf you are still concerned that spyware is on the system please post your hijackthis log in this thread.  And please use the CODE function of this forum to do so.
#14 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 03:57 PM
nlinecomputers......ummm ....  I would surely send you a copy of each one of them (not individually) as far as the event number and catagory type went if I could find this clipboard you are refering to.  I have never done what you are talking about so HELP .. also I have never used that  "code" option, but logically it would be click on "code" and it would end up in one of those boxes ...  yes  ,, no ????
Dale
#15 OFFLINE   nlinecomputers
nlinecomputers
  • 3,932 posts
Posted 10 July 2004 - 04:14 PM
Anything you cut and paste is put into the "clipboard."  Same clipboard as used in Word or Excel or even a webbrowser.When you hightlight text or a file in explorer and hit "copy" or "cut" to move it from one place to another you have put it in the clipboard.  In Event viewer if you hit the copy icon.  That text is now in the clipboard.  You can immediately open notepad, wordpad, Word, or a text box in a browser(like this one) and hit PASTE and presto your clipboard is posted.CODE is used just like QUOTE is.Example:
 Event Type:	ErrorEvent Source:	DCOMEvent Category:	NoneEvent ID:	10005Date:  7/10/2004Time:  5:43:52 AMUser:  NT AUTHORITY\SYSTEMComputer:	NBOXDescription:DCOM got error "The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. " attempting to start the service BITS with arguments "" in order to run the server:{4991D34B-80A1-4291-83B6-3328366B9097}For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Edited by nlinecomputers, 10 July 2004 - 04:19 PM.
#16 OFFLINE   Ed_P
Ed_P
  • 3,095 posts
Posted 10 July 2004 - 04:22 PM
Does this pc run an antivirus longgone?  Was the antivirus installed prior to your selling the pc?  And is it reasonable current?  I agree with Cluttermagnet, this sounds more like a virus than a hardware problem.
Ed
#17 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 04:52 PM
EdP..no anti virus is on this machine at all ... when I build them I don't do any add ons to the basic OS other than the updates from MS and install the software for the CDRW, video card, modem, NIC, or any other such items. I leave the virus choice up to the buyer, what with all the choices there are available. I have on my main machine (which is still broke down) Panda and on the secondary I have AVG with V-catch on both ....
Dale
#18 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 05:07 PM
Event Type:	ErrorEvent Source:	DCOMEvent Category:	NoneEvent ID:	10005Date:  7/5/2004Time:  3:07:45 PMUser:  NT AUTHORITY\SYSTEMComputer:	BUDDA-CCZ5Z3UZSDescription:DCOM got error "This service cannot be started in Safe Mode " attempting to start the service EventSystem with arguments "" in order to run the server:{1BE1F766-5536-11D1-B726-00C04FB926AF}For more information, see Help and Support Center at [URL=http://go.microsoft.com/fwlink/events.asp]http://go.microsoft.com/fwlink/events.asp[/URL].
nlinecomputers .... this is one of the many errors that are listed I can list more but it will take time to do it
Dale
#19 OFFLINE   nlinecomputers
nlinecomputers
  • 3,932 posts
Posted 10 July 2004 - 05:50 PM
This is a normal error if you are trying to start up in safe mode.   Note the time stamps and try to post an error from when you tried to do normal boot up.  Also I'd love to see that error about the CD-ROMs.
#20 OFFLINE   brooster1427
brooster1427
    Contributor
  • PipPip
  • 16 posts
Posted 10 July 2004 - 06:02 PM
You may want to run one of the free virus scans available. Panda, TrendMicro, McAffee etc..There was a virus around that would reboot your machine I think it was one of the Blaster variants but I am not positive. HTH Bruce ;)
#21 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 06:08 PM
[CODE]Event Type: ErrorEvent Source: PlugPlayManagerEvent Category: NoneEvent ID: 12Date: 7/4/2004Time: 3:19:33 PMUser: N/AComputer: BUDDA-CCZ5Z3UZSDescription:The device 'CDWRITER IDE5224' (IDE\CdRomCDWRITER_IDE5224________________________0012____\5&38663351&0&0.0.0) disappeared from the system without first being prepared for removal.For more information, see Help and Support Center at http://go.microsoft....link/events.asp.Data:0000: 00 00 00 00               ....    that is one of the errors having to do with the  CDRW unit will get the other one  in a  minute ...
Dale
#22 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 06:10 PM
Event Type: ErrorEvent Source: CdromEvent Category: NoneEvent ID: 7Date: 7/1/2004Time: 11:34:20 AMUser: N/AComputer: BUDDA-CCZ5Z3UZSDescription:The device, \Device\CdRom0, has a bad block.For more information, see Help and Support Center at http://go.microsoft....link/events.asp.Data:0000: 0e 02 68 00 01 00 b8 00   ..h...¸.0008: 00 00 00 00 07 00 04 c0   .......À0010: 00 01 00 00 00 00 00 00   ........0018: 00 00 00 00 3e 40 02 00   ....>@..0020: 00 00 00 00 00 00 00 00   ........0028: c9 43 00 00 00 00 00 00   ÉC......0030: ff ff ff ff 02 00 00 00   ÿÿÿÿ....0038: 40 00 00 c4 02 00 00 00   @..Ä....0040: 00 00 0c 12 48 00 00 00   ....H...0048: 00 00 00 00 0a 00 00 00   ........0050: 60 9e 9c 01 e8 bc 75 82   `žœ.è¼u‚0058: 00 00 00 00 08 30 56 82   .....0V‚0060: 02 00 00 00 00 00 00 00   ........0068: be 04 00 02 0e 16 00 00   ¾.......0070: 10 f0 00 00 00 00 00 00   .ð......0078: 70 00 03 00 00 00 00 0a   p.......0080: 00 00 00 00 02 00 00 00   ........0088: 00 00 00 00 00 00 00 00   ........that is the second one and one more to come
Dale
#23 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 06:12 PM
Event Type: WarningEvent Source: CdromEvent Category: NoneEvent ID: 51Date: 6/29/2004Time: 4:19:13 PMUser: N/AComputer: BUDDA-CCZ5Z3UZSDescription:An error was detected on device \Device\CdRom0 during a paging operation.For more information, see Help and Support Center at http://go.microsoft....link/events.asp.Data:0000: 03 00 68 00 01 00 b8 00   ..h...¸.0008: 00 00 00 00 33 00 04 80   ....3..€0010: 2d 01 00 00 15 00 00 c0   -......À0018: 00 00 00 00 00 00 00 00   ........0020: 00 00 00 00 00 00 00 00   ........0028: 6c 17 01 00 00 00 00 00   l.......0030: ff ff ff ff 01 00 00 00   ÿÿÿÿ....0038: 40 00 00 c4 02 00 00 00   @..Ä....0040: 00 20 0a 12 48 02 00 40   . ..H..@0048: 00 00 00 00 0a 00 00 00   ........0050: 00 20 c0 65 20 c5 6d 82   . Àe Åm‚0058: 00 00 00 00 98 35 79 82   ....˜5y‚0060: 02 00 00 00 00 00 00 00   ........0068: 28 00 00 00 00 00 00 00   (.......0070: 02 00 00 00 00 00 00 00   ........0078: 70 00 05 00 00 00 00 0a   p.......0080: 00 00 00 00 21 00 00 00   ....!...0088: 00 00 00 00 00 00 00 00   ........and that is the final and last one having to do with the CDRW .. unit
Dale
#24 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 10 July 2004 - 06:18 PM
nlinecomputers ....the post about the "safe mode" was from when the "purchaser" had the machine. The only thing that has occured since I  have been on it today was "one" reboot about 10 mins after I had powered it up. It was a system error catagory 102 event 1003 (according to the log) and since then I have not had a problem. I have shut it off once to change out the ram stick, so I would say the first one is good and this second one appears to be good also.
Dale
#25 OFFLINE   nlinecomputers
nlinecomputers
  • 3,932 posts
Posted 10 July 2004 - 06:44 PM
The CD errors are happening either because you are using a poor copy of a CD-R, a dirty CD that has either finger prints or scratches or you have a bad CD-Rom drive.  Assuming you have good media, It is also possible that you have a bad motherboard or bad cable.  I'd try to reseat your cables, then replace your IDE cables, then replace the CD-ROM drive.
