cybormoron Posted May 1, 2011 Share Posted May 1, 2011 (edited) i installed Debian Squeeze on one of my old test machines. i reallylike it so far. everything is going great 'cept for a few littleproblems which i've easily solved so far.1st little problem: noscript v2.1.0.2 wouldn't install in Iceweasel. anewer version of noscript is available v2.1.0.3 and installs ok.solved.2nd little problem: this is a big annoyance and a possible genuine bug. there's a notification in Nautilus about Personal File Sharing that's super annoying. this page has a comment about how to prevent the notification that works for me. just rename the file. solved. /usr/lib/nautilus/extensions/libnautilus-share-extension.soanother page talks about removing the program that causes it (gnome-user-share). i don't know if this works as i'm not sure if i need the program or not at this time. i tried stopping it from running but that didn't seem to work. so for now i just renamed the file.http://www.linuxquestions.org/questions/de...autilus-835718/3rd little problem: i installed without speakers being plugged in. i don't know if Debian installs sound support by default or not. when i plugged the speakers in i had no sound. i installed a some pulse audio and gstreamer stuff. solved.that's all the problems so far.i'm currently studying how to add more repositories for apt.edit by me, steve. i found a good thread about this right here at Scot's http://forums.scotsnewsletter.com/index.ph...5&hl=debiani don't know if Iceweasel is using flash or gnash plugin. i think it's gnash. youtube works so no probs here. this page tells me i have an old version tho. http://www.mozilla.com/en-US/plugincheck/i might keep this around awhile as i'm getting too tired of hopping around. Edited May 1, 2011 by cybormoron Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 1, 2011 Share Posted May 1, 2011 WAAAAAAAA! I haven't been able to get Squeeze to work on my system yet. I'm jealous. Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 2, 2011 Share Posted May 2, 2011 Good work cybormoron. Works well for me in VBox too.I use and recommend this product. Quote Link to comment Share on other sites More sharing options...
zlim Posted May 5, 2011 Share Posted May 5, 2011 I assume if I want to download an ISO to install to a pendrive, I'd start herehttp://cdimage.debian.org/cdimage/release/current-live/i386/This would be more up to date than my Debian etch on my netbook.Can I make the install on a pendrive persistent? Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 6, 2011 Share Posted May 6, 2011 There's a section on persistence in the wiki. It looks like you need to add a partition image file to the usb key and label it live-rw.See http://live.debian.net/manual/en/html/cust...behaviours.html Quote Link to comment Share on other sites More sharing options...
zlim Posted May 6, 2011 Share Posted May 6, 2011 Thanks sunrat for the info and link; I'm off to do some reading. Quote Link to comment Share on other sites More sharing options...
