abarbarian Posted March 26, 2015 Share Posted March 26, 2015 Boy oh boy does this dmidecode give some thorough information.here is just a small part of the output for my rig. # dmidecode # dmidecode 2.12 SMBIOS 2.4 present. 78 structures occupying 2288 bytes. Table at 0x000F0000. Handle 0x0000, DMI type 0, 20 bytes BIOS Information Vendor: Phoenix Technologies, LTD Version: ASUS M2N32-SLI DELUXE ACPI BIOS Revision 2209 Release Date: 09/07/2009 Address: 0xE0000 Runtime Size: 128 kB ROM Size: 1024 kB Characteristics: PCI is supported PNP is supported APM is supported BIOS is upgradeable BIOS shadowing is allowed Boot from CD is supported Selectable boot is supported BIOS ROM is socketed EDD is supported 5.25"/360 kB floppy services are supported (int 13h) 5.25"/1.2 MB floppy services are supported (int 13h) 3.5"/720 kB floppy services are supported (int 13h) 3.5"/2.88 MB floppy services are supported (int 13h) Print screen service is supported (int 5h) 8042 keyboard services are supported (int 9h) Serial services are supported (int 14h) Printer services are supported (int 17h) CGA/mono video services are supported (int 10h) ACPI is supported USB legacy is supported LS-120 boot is supported ATAPI Zip drive boot is supported BIOS boot specification is supported Handle 0x0004, DMI type 4, 35 bytes Processor Information Socket Designation: Socket AM2 Type: Central Processor Family: Athlon 64 Manufacturer: AMD ID: 43 0F 10 00 FF FB 8B 17 Signature: Family 16, Model 4, Stepping 3 Flags: FPU (Floating-point unit on-chip) VME (Virtual mode extension) DE (Debugging extension) PSE (Page size extension) TSC (Time stamp counter) MSR (Model specific registers) PAE (Physical address extension) MCE (Machine check exception) CX8 (CMPXCHG8 instruction supported) APIC (On-chip APIC hardware supported) SEP (Fast system call) MTRR (Memory type range registers) PGE (Page global enable) MCA (Machine check architecture) CMOV (Conditional move instruction supported) PAT (Page attribute table) PSE-36 (36-bit page size extension) CLFSH (CLFLUSH instruction supported) MMX (MMX technology supported) FXSR (FXSAVE and FXSTOR instructions supported) SSE (Streaming SIMD extensions) SSE2 (Streaming SIMD extensions 2) HTT (Multi-threading) Version: AMD Phenom(tm) II X4 965 Processor Voltage: 1.5 V External Clock: 200 MHz Max Speed: 3700 MHz Current Speed: 800 MHz Status: Populated, Enabled Upgrade: Socket 940 L1 Cache Handle: 0x000C L2 Cache Handle: 0x000E L3 Cache Handle: Not Provided Serial Number: Asset Tag: Part Number: I am interested in this output as I can not get the cpu to run at full speed or use any governing. :'( 3 Quote Link to comment Share on other sites More sharing options...
