Guest ajb Posted May 14, 2003 Share Posted May 14, 2003 Hi,I need to make Mozilla my default browser for hyperlinks and stuff. I use Knode for news and Kmail for e-mail and both open Konqueror when clicking on hyperlinks.How do I change that?I am using Mandrake 9.1Thanks,AJ Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 14, 2003 Share Posted May 14, 2003 Hi ajbWelcome to the All Things Linux Forum.Nice to see you use Mandrake aswell, I´m an absolute fan of Mandrake but you might have noticed that already reading the posts on this forum. :)As for your question: Kmail always opens Konqueror they are both of the same KDE package. Sure you could use evolution as mail program and that would solve your problem, but if you want to stick with Kmail ( I guess you do ) you will have to give me a little time to figure it out . . . . just have no ready to go answer for you ! ;)I will look into this and come back to you in this thread soon ! Bruno Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 14, 2003 Share Posted May 14, 2003 ajb --Just like in Windows it is a matter of changing associations for html type files.Try this:KDE "start">Control Center>FileBrowsing>File Associations>text>html>in application list click "add">in the "choose application box" type: /usr/bin/mozilla -newwindow %u (you may have to change this to suit your version of mozilla, and it's location) Click OK. You can then highlight the mozilla entry you just made and move it to the top of the list of applications that will handle html. When you click a link, mozilla should be called to open it.This should work in any version of Mandrake from 8.x - current 9.1 version. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 14, 2003 Share Posted May 14, 2003 Nice one LilBambi, I was just 10 minutes to late with this one ! Looks like the same solution I came with !Fair play to you, you won ! B) Bruno Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 14, 2003 Share Posted May 14, 2003 Glad we came up with the same solution, Bruno. Just trying to help a fella out. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 14, 2003 Share Posted May 14, 2003 You´re right Fran that´s what we do ! Bruno Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 14, 2003 Share Posted May 14, 2003 Yep Quote Link to comment Share on other sites More sharing options...
GolfProRM Posted May 14, 2003 Share Posted May 14, 2003 Quick update... In Mandrake 9.1, it's under KDE "start" -> Control Center -> Components -> File Associations -> Text -> htmlIn mine, Mozilla was already in the list, so I guess all you'd have to do is move it up to the top... Simple as that! Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted May 15, 2003 Share Posted May 15, 2003 Cool! Thanks Ryan for the update! Quote Link to comment Share on other sites More sharing options...
