Stryder Posted May 13, 2003 Share Posted May 13, 2003 You mentioned croms, I think that is the word. I leave my PC on all the time, do I need to set anything up to make sure all the routines that linux runs automatically gets done? Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 13, 2003 Share Posted May 13, 2003 Stryder,Cron-jobs is the word, if your computer is on all the time you don´t have to install any extra software to run it !The cron deamon works at 3 or 4 o´clock at night, updates your databases for the search function, the rpm database and several others, also it compresses log-files ( logrotate ) and other maintenace stuff.Only people who shut down their computer at night might never get those hard needed jobs done. they should install ¨anacron¨ to pick up the forgotten jobs a few minutes after booting their computer.If you want you can add jobs to cron to be run at certain times a day, a week or a month. I will be doing a topic on adding cron-jobs soon in the ¨Starters Tips¨. Bruno Quote Link to comment Share on other sites More sharing options...
