More Partitions . . More Distro's to boot
845 replies to this topic
#51 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 02:13 PM
Bruno......Yes ,,, that  is all that was in there  ... at  least  in  9.0  ..... 10.0  is a  different matter
Dale
U.S. Navy (ret.) '62 - '84
Communications (Radioman)
Reg. Linux User 412421
#52 OFFLINE   Bruno
Bruno
    Le Professeur Pingouin
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 02:20 PM
Now you can boot in Drake 10 and post from there:
$ su< password ># cat /etc/lilo.conf
;) Bruno
#53 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 02:29 PM
;)  :o Back in 10 ....  here it is all that stuff ....Password:[root@localhost dale]# cat /etc/lilo.conf# File generated by DrakX/drakboot# WARNING: do not forget to run lilo after modifying this fileboot=/dev/hdb1map=/boot/mapdefault="linux-i686-up-4GB"keytable=/boot/us.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz        label="linux"        root=/dev/hdb1        initrd=/boot/initrd.img        append="devfs=mount acpi=ht splash=silent"        vga=788        read-onlyimage=/boot/vmlinuz        label="linux-nonfb"        root=/dev/hdb1        initrd=/boot/initrd.img        append="devfs=mount acpi=ht"        read-onlyimage=/boot/vmlinuz-i686-up-4GB        label="linux-i686-up-4GB"        root=/dev/hdb1        initrd=/boot/initrd-i686-up-4GB.img        append="devfs=mount acpi=ht splash=silent"        read-onlyimage=/boot/vmlinuz-2.6.3-7mdk        label="263-7"        root=/dev/hdb1        initrd=/boot/initrd-2.6.3-7mdk.img        append="devfs=mount acpi=ht splash=silent"        read-onlyimage=/boot/vmlinuz        label="failsafe"        root=/dev/hdb1        initrd=/boot/initrd.img        append="failsafe acpi=ht devfs=nomount"        read-onlyother=/dev/fd0        label="floppy"        unsafeother=/dev/hda3        label="Windows-XP"        table=/dev/hda[root@localhost dale]#
Dale
#54 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 02:34 PM
Good . . looks good to me . . now remember the default boot is the "linux-i686-up-4GB" . . so that is the one you want to boot from after you did:
# /sbin/lilo
Now you reboot and check if indeed you have the new Drake 10 boot-menu . . and you boot the "linux-i686-up-4GB" after that report back to me that all was OK :DB) Bruno
#55 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 02:53 PM
[root@localhost dale]# /sbin/liloAdded linuxAdded linux-nonfbAdded linux-i686-up-4GB *Added 263-7Added failsafeAdded floppyAdded Windows-XP
Dale
#56 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 02:57 PM
Good . . we will have to slim that down in a moment . . but first: did you reboot and boot up in the "linux-i686-up-4GB" ??;) Bruno
#57 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 02:59 PM
B)  :o  ;) Well ....  I  rebooted  and  by  default .... I am posting from   9.0 ....   something did not  come out according to Hoyle
Dale
#58 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 03:06 PM
Very strange !! Very very strange indeed !Okay reboot using the boot-CD in Drake 10 . . . and once in drake 10 do:
$ su< password > # /sbin/lilo -b /dev/hda
And try again to reboot after that . . . ;) Bruno
#59 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 03:13 PM
Bruno ....before I re-boot  (or try to)  this is what the results of he last command  arePassword:[root@localhost dale]# /sbin/lilo -b /dev/hdaIgnoring entry 'boot'Added linuxAdded linux-nonfbAdded linux-i686-up-4GB *Added 263-7Added failsafeAdded floppyAdded Windows-XP[root@localhost dale]#
Dale
#60 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 03:17 PM
Yep . . . reboot . . . . . now it has to work !;) Bruno
#61 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 03:29 PM
:clap:  :clap:  :o  B)  ;) Bruno...,,,We have lift off .... rebooted into 10.0 ,, posting now  ....  Onward into that Valley of Linux .. I shall go ... going where I have not gone before ... opening new distros I have not yet begun to know .... Onward I say ,,, Onward
Dale
#62 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 03:31 PM
HURRAY !!!Now we have to remember: "/sbin/lilo -b /dev/hda" . . . make a note of that one !!First I want to weed out the lilo of unneeded entries . . . let me see:
# ls -al /boot
;) Bruno
#63 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 03:37 PM
Password:[root@localhost dale]# ls -al /boottotal 6032drwxr-xr-x   3 root root    4096 Jun 19 12:16 ./drwxr-xr-x  21 root root    4096 Jun 19 12:15 ../-rw-r--r--   1 root root     512 Jun 19 12:09 boot.0300-rw-r--r--   1 root root     512 Jun  3 05:24 boot.0341lrwxrwxrwx   1 root root      29 Jun 19 12:15 config -> config-2.6.3-7mdk-i686-up-4GB-rw-r--r--   1 root root   54087 Mar 17 06:58 config-2.6.3-7mdk-rw-r--r--   1 root root   54189 Mar 17 06:19 config-2.6.3-7mdk-i686-up-4GB-rw-r--r--   1 root root    5032 Feb 19 09:03 diag1.img-rw-r--r--   1 root root   16796 Feb 19 09:03 diag2.imgdrwxr-xr-x   2 root root    4096 Jun  3 05:09 grub/-rw-r--r--   1 root root  108741 Jun  3 05:23 initrd-2.6.3-7mdk-i686-up-4GB.img-rw-r--r--   1 root root  134353 Jun  3 05:23 initrd-2.6.3-7mdk.imglrwxrwxrwx   1 root root      33 Jun  3 05:23 initrd-i686-up-4GB.img -> initrd-2.6.3-7mdk-i686-up-4GB.imglrwxrwxrwx   1 root root      21 Jun  3 05:23 initrd.img -> initrd-2.6.3-7mdk.imglrwxrwxrwx   1 root root      37 Jun 19 12:16 kernel.h -> /boot/kernel.h-2.6.3-7mdk-i686-up-4GB-rw-r--r--   1 root root     537 Jun 17 03:07 kernel.h-2.6.3-7mdk-rw-r--r--   1 root root     537 Jun  3 07:06 kernel.h-2.6.3-7mdk-i686-up-4GB-rw-------   1 root root  550400 Jun 19 12:09 maplrwxrwxrwx   1 root root      15 Jun 18 10:56 message -> message-graphic-rw-r--r--   1 root root  442273 Jun  3 05:23 message-graphic-rw-r--r--   1 root root     116 Jun  3 05:24 message-textlrwxrwxrwx   1 root root      33 Jun 19 12:15 System.map -> System.map-2.6.3-7mdk-i686-up-4GB-rw-r--r--   1 root root  898908 Mar 17 06:58 System.map-2.6.3-7mdk-rw-r--r--   1 root root  900900 Mar 17 06:19 System.map-2.6.3-7mdk-i686-up-4GB-rw-r--r--   1 root root     256 Jun  3 05:24 us.kltlrwxrwxrwx   1 root root      18 Jun  3 05:23 vmlinuz -> vmlinuz-2.6.3-7mdk-rw-r--r--   1 root root 1440198 Mar 17 06:58 vmlinuz-2.6.3-7mdk-rw-r--r--   1 root root 1468886 Mar 17 06:19 vmlinuz-2.6.3-7mdk-i686-up-4GBlrwxrwxrwx   1 root root      30 Jun  3 05:23 vmlinuz-i686-up-4GB -> vmlinuz-2.6.3-7mdk-i686-up-4GB[root@localhost dale]#considerable amout there
Dale
#64 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 03:46 PM
Okay . . we will make changes in /etc/lilo.conf . . . so "kedit /etc/liloconf" and make the following changes: ( Be carefull and accurate ! )
# File generated by DrakX/drakboot# WARNING: do not forget to run lilo after modifying this fileboot=/dev/hdb1map=/boot/mapdefault="Mandrake-10" <==============CHANGE !keytable=/boot/us.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz   label="Mandrake-Backup"  <==============CHANGE !   root=/dev/hdb1   initrd=/boot/initrd.img   append="devfs=mount acpi=ht splash=silent"   vga=788   read-onlyimage=/boot/vmlinuz   label="linux-nonfb"   root=/dev/hdb1   initrd=/boot/initrd.img   append="devfs=mount acpi=ht"   read-onlyimage=/boot/vmlinuz-i686-up-4GB   label="Mandrake-10"  <==============CHANGE !   root=/dev/hdb1   initrd=/boot/initrd-i686-up-4GB.img   append="devfs=mount acpi=ht splash=silent"   read-onlyimage=/boot/vmlinuz-2.6.3-7mdk  <==============DELETE !   label="263-7"  <==============DELETE !   root=/dev/hdb1  <==============DELETE !   initrd=/boot/initrd-2.6.3-7mdk.img  <==============DELETE !   append="devfs=mount acpi=ht splash=silent"  <==============DELETE !   read-only  <==============DELETE !image=/boot/vmlinuz   label="failsafe"   root=/dev/hdb1   initrd=/boot/initrd.img   append="failsafe acpi=ht devfs=nomount"   read-onlyother=/dev/fd0   label="floppy"   unsafeother=/dev/hda3   label="Windows-XP"   table=/dev/hda
The save the file and again do:
And let me see the result . . . :DB) Bruno
#65 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 04:06 PM
Here  are the results  of the   menu  reduction  paln  ....[root@localhost dale]# /sbin/lilo -b /dev/hdaIgnoring entry 'boot'Added Mandrake-BackupAdded linux-nonfbAdded Mandrake-10 *Added failsafeAdded floppyAdded Windows-XP[root@localhost dale]#
Dale
#66 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 04:14 PM
That looks perfect Dale !!Now remember the "Mandrake-10" is your *normal* boot for Drake 10 . . . the "Mandrake-Backup" is only there only for emergency, if ever the normal kernel refuses to boot we can try that one . . .;) . . .The "linux-nonfb" and "failsafe" are troubleshooters that you will probably never use but they have to be there !So now we have a clear boot-menu . .  and now we can add the other 7 distros you will install . . :D :D . . So go ahaid and install Mepis on /dev/hda8 . . at the end of the install just let it place Lilo in the MBR so you can check if Mepis will boot from it . . . .  .Later we will place the Drake Lilo back in the MBR and add Mepis to it.Have a good install Dale ! :D :DB) Bruno
#67 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 04:19 PM
:D  :D I'll   be  back  .......................... ;)
Dale
#68 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 04:20 PM
LOL . . .  . . .. I am sure you will my friend !! ;) :DB) Bruno
#69 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 05:20 PM
:D  :o  :D I'm back ....    :D  and Mepis is installed on hda8 (I think/believe) at least that is the one that I selected. Now on to other gliches ... it won't connect to the  web  ... I had this same problem the first time with Mepis ,,, came back in here to the original thread somewhere around page 9-11    or so  .. and got the info you  gave me  ..as root  ....  rm -rf /dev/modemln -s /dev/ttys4 /dev/modemmake a sym link from  ttys4  to the  dev/modem  since it does not give me the opportunity to select  ttys4 during the install process. Well  fudge (with walnuts) it did not work .. I get the  error  unable to open modem  .. tried this twice  .. same response both times ... also at the beginning of the install when I selected hda8 it  is set up as root (no other partitions), I could not add a home to hda8, is that going to come later, leave it as it is or install again differently ????? ;)  :D
Dale
#70 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 05:30 PM
Hi DaleNope not install again . . . we will first add Mepis to lilo.As for hda8 and /home . . . it is simple: all is on hda, including /home so that is 100% okay ! That is the way we want it !As for the modem: you should not select /ttys4 when you set up the modem, but /dev/modem . . but more about that later . . let us first do Lilo:Boot into Drake-10 . . and do the following commands:
$ su< password ># mkdir /mnt/hda8# mount /dev/hda8 /mnt/hda8# ls -al /mnt/hda8/boot
And post me the outcome . . ;) Bruno
#71 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 05:37 PM
In 10  and nowPassword:[root@localhost dale]# mkdir /mnt/hda8[root@localhost dale]# mount /dev/hda8 /mnt/hda8[root@localhost dale]# ls -al /mnt/hda8/boottotal 1576drwxr-xr-x   2 root root    4096 Jun 19  2004 ./drwxr-xr-x  18 root root    4096 Jun 19  2004 ../-rw-r--r--   1 root root     512 Jun 19  2004 boot.0300-rw-r--r--   1 root root   38572 Nov 14  2003 config-2.4.22-rw-------   1 root root   36864 Jun 19  2004 map-rw-r--r--   1 root root   76880 Nov 16  2003 memtest86.bin-rwxr-xr-x   1 root root   15352 Nov 20  2003 mepis.bmp*-rw-r--r--   1 root root  389420 Nov 14  2003 System.map-2.4.22-rw-r--r--   1 root root 1019969 Nov 19  2003 vmlinuz-2.4.22[root@localhost dale]#
Dale
#72 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 05:38 PM
Good ! Next step:
# cp -r  /mnt/hda8/boot  /boot/mepis# ls  /boot/mepis
;) Bruno
#73 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 05:42 PM
Bruno ...........[root@localhost dale]# ls /boot/mepisboot.0300      map            mepis.bmp*         vmlinuz-2.4.22config-2.4.22  memtest86.bin  System.map-2.4.22[root@localhost dale]#
Dale
#74 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 19 June 2004 - 05:47 PM
Great . . now we adapt /etc/liloconf again . . . . see here:
# File generated by DrakX/drakboot# WARNING: do not forget to run lilo after modifying this fileboot=/dev/hdb1map=/boot/mapdefault="Mandrake-10"keytable=/boot/us.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz  label="Mandrake-Backup"  root=/dev/hdb1  initrd=/boot/initrd.img  append="devfs=mount acpi=ht splash=silent"  vga=788  read-onlyimage=/boot/mepis/vmlinuz-2.4.22        label="Mepis"        root=/dev/hda8         vga=788         read-onlyimage=/boot/vmlinuz  label="linux-nonfb"  root=/dev/hdb1  initrd=/boot/initrd.img  append="devfs=mount acpi=ht"  read-onlyimage=/boot/vmlinuz-i686-up-4GB  label="Mandrake-10"   root=/dev/hdb1  initrd=/boot/initrd-i686-up-4GB.img  append="devfs=mount acpi=ht splash=silent"  read-onlyimage=/boot/vmlinuz  label="failsafe"  root=/dev/hdb1  initrd=/boot/initrd.img  append="failsafe acpi=ht devfs=nomount"  read-onlyother=/dev/fd0  label="floppy"  unsafeother=/dev/hda3  label="Windows-XP"  table=/dev/hda
I inserted a few white lines . . so we get more clarity for future additions ;)After saving the file we do again:
And show me the result ;) :DB) Bruno
#75 OFFLINE   longgone
longgone
  • 5,155 posts
Posted 19 June 2004 - 05:54 PM
Bruno ..... [root@localhost dale]# /Mutex destroy failure: Device or resource busysbin/lilo -ICE default IO error handler doing an exit(), pid = 3045, errno = 0b /dev/hdaIgnoring entry 'boot'Added Mandrake-BackupAdded MepisAdded linux-nonfbAdded Mandrake-10 *Added failsafeAdded floppyAdded Windows-XP[root@localhost dale]#
Dale
