WE are at Distro Search for Stability not burnout!
215 replies to this topic
#26 OFFLINE   Bruno
Bruno
    Le Professeur Pingouin
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 03:41 PM
Hi Colin
$ kdesu kwrite /etc/lilo.conf
Make the change . . . . save the file . . . and:
$ su# /sbin/lilo
:whistling: Bruno
#27 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 03:52 PM
BrunoI DID that and am on the first reboothave NOT ventured into sound or  Updates yetColin  :whistling:
Registered Linux User: # 440412
Kamicotas Homepage
#28 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 03:54 PM
One thing at a time . . . . Let us fix the reboot/shutdown first . . . . .  B) Bruno
#29 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 03:55 PM
Righty Ho BrunoJust thought I'd let you know where we were atSecond reboot now and it DID shut all the way downColin B)
Kamicotas Homepage
#30 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 03:57 PM
Good . . . . . now get the updates . . . all of them :D( that will give me time to read the 34 emails I still have un-read/un-answered in my inbox B) )B) Bruno
#31 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 03:59 PM
Thank you BrunoShutdown goes all the way DOWN and SO DOES reboot it does not restartBut that is OKOff for UpdatesColin  B)
Kamicotas Homepage
#32 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 05:20 PM
Righty Ho BrunoUPDATES are done B) A little info--->>>last Startup BEFORE Updates I go the SOUND SERVER errorand also AFTER the UpdatesI have NOT tried anything with sound Kmix or anything yetColin  :D
Kamicotas Homepage
#33 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 05:39 PM
Okay Colin . . . let us tackle the sound . . . :
# cat /etc/hotplug/blacklist
B) Bruno
#34 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 05:41 PM
Righty Ho BrunoCan I use the Konsole while I am on the last 6 of my OOo 2.0.1 Downloads and send the resultColin  :thumbsup:OOPS they are installing nowWill p[ost as soon as installedCol,in
Edited by kamicota, 23 February 2006 - 05:42 PM.
Kamicotas Homepage
#35 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 05:43 PM
Okay  . . take your time . . . no hurry . . ;)B) Bruno
#36 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 05:45 PM
here they are Bruno  B) [kamicota@localhost ~]$ suPassword:[root@localhost kamicota]# cat /etc/hotplug/blacklist## Listing a module here prevents the hotplug scripts from loading it.# Usually that'd be so that some other driver will bind it instead,# no matter which driver happens to get probed first.  Sometimes user# mode tools can also control driver binding.## Syntax:  driver name alone (without any spaces) on a line. Other# lines are ignored.## uhci ... usb-uhci handles the same pci classusb-uhci# usbcore ... module is loaded implicitly, ignore it otherwiseusbcore# tulip ... de4x5, xircom_tulip_cb, dmfe (...) handle same devicesde4x5# At least 2.4.3 and later xircom_tulip doesn't have that conflict# xircom_tulip_cbdmfe#evbug is a debug tool and should be loaded explicitlyevbug# audio, snd-usb-audio handle same class devices:# snd-usb-audio b/c it breaks sound & alsa services else:[root@localhost kamicota]#Colin  :D
Kamicotas Homepage
#37 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 05:52 PM
Okay . . . we will add 2 lines at the bottom of that file . . first we open it in kwrite:
 $ kdesu kwrite /etc/hotplug/blacklist
Then you add these 2 lines at the bottom:
snd-attixp-modemsnd-atiixp
Then you save the file and show me again:
B) Bruno
#38 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 05:54 PM
[kamicota@localhost ~]$ suPassword:[root@localhost kamicota]# cat /etc/hotplug/blacklist## Listing a module here prevents the hotplug scripts from loading it.# Usually that'd be so that some other driver will bind it instead,# no matter which driver happens to get probed first.  Sometimes user# mode tools can also control driver binding.## Syntax:  driver name alone (without any spaces) on a line. Other# lines are ignored.## uhci ... usb-uhci handles the same pci classusb-uhci# usbcore ... module is loaded implicitly, ignore it otherwiseusbcore# tulip ... de4x5, xircom_tulip_cb, dmfe (...) handle same devicesde4x5# At least 2.4.3 and later xircom_tulip doesn't have that conflict# xircom_tulip_cbdmfe#evbug is a debug tool and should be loaded explicitlyevbug# audio, snd-usb-audio handle same class devices:# snd-usb-audio b/c it breaks sound & alsa services else:snd-attixp-modemsnd-atiixp[root@localhost kamicota]#Thanks BrunoColin  B)
Kamicotas Homepage
#39 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 05:59 PM
Okay . . . .  .next step:
$ kdesu kwrite /etc/rc.d/rc.local
And add these 4 lines at the bottom of the file:
modprobe snd-atiixpsleep 1amixer set Master 90% unmuteamixer set PCM 90% unmute
Then save the file and show me:
$ cat  /etc/rc.d/rc.local
B) Bruno
#40 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:03 PM
[kamicota@localhost ~]$ cat  /etc/rc.d/rc.local#!/bin/sh## This script will be executed *after* all the other init scripts.# You can put your own initialization stuff in here if you don't# want to do the full Sys V style init stuff.touch /var/lock/subsys/localif [ -f /etc/LIVECD ] ; thenecho "Trying to start graphical desktop. If for some reason this failsplease log in here with name root password root, type video to set yourvideo card and then type startx to get to the desktop" > /etc/issuefimodprobe snd-atiixpsleep 1amixer set Master 90% unmuteamixer set PCM 90% unmute [kamicota@localhost ~]$ B) Colin
Kamicotas Homepage
#41 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 06:04 PM
Cool . . . now reboot and report back after the reboot.B) Bruno
#42 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:09 PM
Righty Ho bruno--->>> B)  :D NO error message this timeColin  B)
Kamicotas Homepage
#43 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 06:11 PM
Now do: ( as USER )
$ /usr/bin/play /usr/share/sounds/KDE_Startup.wav
Do we hear sound ? B) Bruno
#44 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:13 PM
B) YESColin :D
Kamicotas Homepage
#45 OFFLINE   Bruno
Bruno
  • Admin Emeritus
  • 37,904 posts
Posted 23 February 2006 - 06:19 PM
Means your sound is fixed Colin !!! :DThank Julia for it because she posted the instructions for it in the other thread ;)B) Bruno
#46 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:22 PM
yep BrunoI think I took OFF when I could NOT get X or Y to work NOT realizing it needed CTRL X and CTRL YBut until such times as Julia is on the forum again and I can thank her face to face--->>>Thank you  B) Julia and teach desreves some  :D  B)  :flowers: TOOCheers for YearsColin
Kamicotas Homepage
#47 OFFLINE   teacher
teacher
    Acute Mac
  • Honorary Moderators
  • 13,854 posts
Posted 23 February 2006 - 06:27 PM
Gee what a sweet wa to come back after my swim.  B)
Teacher
Beach Bum Extraordinaire
#48 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:29 PM
Boy JuliaYOUR TIMING is IMPECCABLE and  :D thank you for the "SWEET" tooBecause of you and bruno WE are NOW back on track  :flowers:  B) Colin  B)  :D
Kamicotas Homepage
#49 OFFLINE   teacher
teacher
    Acute Mac
  • 13,854 posts
Posted 23 February 2006 - 06:31 PM
I'm just glad to hear you worked through all of that.  Now take some time to explore and enjoy.  I just ran through 250MB of updates and new installs while reading through today's adventure.  B)
Teacher
#50 OFFLINE   kamicota
kamicota
  • 8,358 posts
Posted 23 February 2006 - 06:35 PM
Yes JuliaIt IS TIME to EXPLORE & ENJOY both on the Desktop & the LaptopThis LITTLE ADVENTURER  B) has still more up his sleeve--->>>Probably an HP Deskjet 5440 to get this weekend TOTALLY for PCLos Desktop B) Will have to ASK  :P Laptop/PCLos what it NEEDS NOW eh  :D  :D  :P Colin  :flowers:
Edited by kamicota, 23 February 2006 - 06:37 PM.
Kamicotas Homepage
