linuxGreen Posted August 5, 2003 Share Posted August 5, 2003 Hi Guys, Finally, I installed SUSE. The installation was very easy, I did not expected. However, I ran into a problem, and I cannot find an answer in the manual. Maybe one of you, gurus, know the answer. Once, I was trying to exit suse and reboot to windows, I clicked exit.I was expecting a reboot procedure but instead I got xconsole window. I was trying to go back to window menu with Yast manager, but I do not know how to get there. My window looks in the following way:once I click and hold my left mouse button I get something called TWM:and several lines of commands:IconfigResize etc, Can you tell what to do to get back to window mode. Quote Link to comment Share on other sites More sharing options...
Prelude76 Posted August 5, 2003 Share Posted August 5, 2003 i did same thing shortly after installing SUSE.basically, it seems you are in a different window manager. when loggin' in, it asks Username, password, and then you have a list to choose from. i recommend only using KDE until you get more proficient. GNOME desktop is also easy, but some of the others, probably one you chose accidentaly as i did, have virtual no GUI or icons or menu. i forget how i got out of it myself. i think i did a hard reboot. either that, or try CTRL-ALT-ESC Quote Link to comment Share on other sites More sharing options...
teacher Posted August 5, 2003 Share Posted August 5, 2003 Does startx work? Quote Link to comment Share on other sites More sharing options...
zox Posted August 5, 2003 Share Posted August 5, 2003 Try right-clicking, or scrool-wheel clicking if you happen to have scrool-wheel on your mouse, or ALT-left or ALT-right click, or simply kill X with CTRL+ALT+Backspace and start Suse in KDE Window manager instead. Quote Link to comment Share on other sites More sharing options...
linuxGreen Posted August 6, 2003 Author Share Posted August 6, 2003 Thanks Guys, I will try all you solutions tomorrow morning once I get to work. you are just great bunch of people...Chris Quote Link to comment Share on other sites More sharing options...
