lewkh Posted June 17, 2005 Share Posted June 17, 2005 Hi Folks, I make a simple folder sharing in Windowx Storage 2003, as right click the folder and go to sharing and security tag and make a sharing on network. Could anyone tell me that how do I restart the sharing service on Windows? Is it the netbios? What is the name for providing network sharing in Windows? Please advise.... Quote Link to comment Share on other sites More sharing options...
lewkh Posted July 20, 2005 Author Share Posted July 20, 2005 file sharing is provided by the SERVER service.something like this:C:\WINDOWS\system32\svchost.exe -k netsvcs <{POST_SNAPBACK}> Hi Temmu, I have tried the command you gave me... There is nothing after I typed the command ended with enter. ( I typed the command at cmd propmt)It just return a blank line and the prompt within a minute. Is it correct? Please advise... Quote Link to comment Share on other sites More sharing options...
lewkh Posted July 28, 2005 Author Share Posted July 28, 2005 if file and printer sharing is disabled / removed from network settings, then the server service may not show up in the services list.network properties:control panel, network connections, r click the network, properties.(look to see if file & printer sharing is there.)to add file and printer sharing, from there,install... service, add, file and printer sharingto start the service:r click my computer, manage, services and applications, servicesr click server, properties, set to automatic, click start<{POST_SNAPBACK}> Hi Temmu I knew how to start and stop the services by using the Windows GUI. My problem is how do I remotely access to Windows box to restart the service?I have tried the command at command prompt, but it seem to be nothing. May I know the parameter -k stand for what? Why should I use the svchost.exe to restart the netsvcs instead of using something like net.exe to restart? Please advise me if I am doing wrongly... Quote Link to comment Share on other sites More sharing options...
