tale of two lappys
52 replies to this topic
#1 OFFLINE   wa4chq
wa4chq
    Message Mogul
  • PipPipPipPipPip
  • 439 posts
Posted 09 September 2016 - 09:36 AM
Good morning....
I have two laptops that I use, the Lenovo E420 is my main lappy which runs Slackware.  The other is an older Dell which dual boots WinXP (don't ask) and Mint something....
I really only use the Dell for watching movies.  Mint had been playing my Netflix DVD's just fine up until maybe a month ago when every other one I received would hang up but resume sporadically or not play at all.  I'd clean the discs and even cleaned the reader....no luck.  During my research for solutions I found something about pclinuxos.  I know there are users here.  I've never messed with it but the article sparked my interest and I decided to download the latest Mate Desktop and install it to a flash drive and then test drive it booting the live format.  Let me back up a little... when I had the problems with the movies, I tried using the Lenovo and couldn't get them to play either, missing slackpkg maybe?
Booted it using the Lenovo, I inserted the movie and saw that it would not play....looking at the VLC log it said "lib64dvdcss2" was missing.  So I added another repository, found the lib and installed it.  VLC played the movie (The Martian)!  OK, so it wasn't the disk.  Now, the latest version of PCLinuxOS is for 64bit and the Dell is 32....so I'm gonna have to download and earlier version.  It would be great if I could create a persistent, bootable flash version but I didn't see anything for doing that with PCLinuxOS....maybe Unetbootin?  Either way, having the live version I will be able to test the Dell to see if Netflix DVD's play.  If it does I have no problem getting rid of Mint and just install a 32bit PCLinuxOS to the Dell....
Now why Mint quit playing the movies, I don't know unless it's an update issue (or I could look at the VLC log and see if there is an error and try and fix it) but to be honest, I'd rather try something different.  :)
Have a great weekend.
REGISTERED LINUX USER #547579
#2 OFFLINE   securitybreach
  • 23,647 posts
Posted 09 September 2016 - 10:19 AM
Any errors on Mint while playing a movie? Can you launch vlc via the command line and look for any errors when trying to play the dvd?
#3 OFFLINE   wa4chq
wa4chq
    Message Mogul
  • PipPipPipPipPip
  • 439 posts
Posted 09 September 2016 - 12:52 PM
No, I haven't done that but will this evening.  But I think I may still install PCLinuxOS if the live version for 32bit boots and etc....
#4 OFFLINE   abarbarian
  • 5,553 posts
Posted 09 September 2016 - 06:58 PM
I, (of course) suggest you format the drive with one ext4 partition, and use PCLinuxOS LiveUSB Creator to do the live install.
If you select, when offered the option, to include a 'Persistent' boot option then it will retain changes you make and they will be there the next time you boot in Persistent mode, and not there if you boot in Standard mode.
http://www.pclinuxos...topic=138097.15
Couldn't reist :devil:
The quote is from post 18.
Install ARCH
"I did and I'm really happy"
#5 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,379 posts
Posted 09 September 2016 - 08:43 PM
Texstar isn't supporting 32 bit anymore, huh? That's interesting. I noticed, though, you can download community versions of PCLinuxOS that do support 32 bit. I'm assuming that's probably what you did already, though.
    #6 OFFLINE   securitybreach
    • 23,647 posts
    Posted 10 September 2016 - 08:23 AM
    BTW does the processor in the Dell not support 64bit?
    #7 OFFLINE   Hedon James
    Hedon James
      Topic Cop
    • PipPipPipPipPipPipPip
    • 818 posts
    Posted 10 September 2016 - 10:17 AM
    Did WinXP ever come in a 64-bit version?  I honestly don't know.  I know there are 32-bit and 64-bit Win7s, but Win7 tends to be 64-bit.  Likewise, WinXP tends to be 32-bit, unless its WinXP Pro, which tends to be 64-bit.
    DOH....brain fart.  Just because WinXP 32-bit was installed, doesn't necessarily mean his CPU was 32-bit.  Certainly could've been a 32-bit OS on a 64-bit CPU.  My bad...
    Type "lscpu" in a terminal wa4chq and you will have your answer.  More info here on deciphering the output:
    http://askubuntu.com...or-64-or-32-bit
    #8 OFFLINE   securitybreach
    • 23,647 posts
    Posted 10 September 2016 - 10:28 AM
    Yes, there was a 64bit version of Windows. https://en.wikipedia...nal_x64_Edition
    And you are correct, just because 32bit came installed doesn't mean that the processor can do 64bit.  For a long while, company's based it upon how much ram came preinstalled but that doesn't mean it is a limitation. I had a few machines that came with a 32bit OS but was 64 bit capable.
    #9 OFFLINE   wa4chq
    wa4chq
      Message Mogul
    • PipPipPipPipPip
    • 439 posts
    Posted 10 September 2016 - 02:24 PM
    Hey abarbarian....I looked at pclinuxos live usb creator...but it said that I needed a working installation of pclinuxos....which I don't.....  :(
    Eric, I tried two 32bit versions from the community and I couldn't get them to work on my flash drive for some reason....I found another site with older version that I'm gonna try.
      Nocturnal Slacker
    • 21,379 posts
    Posted 10 September 2016 - 05:42 PM
    What model Dell?
    #11 OFFLINE   abarbarian
    • 5,553 posts
    Posted 11 September 2016 - 04:36 AM
    http://www.pclinuxos...p?topic=82277.0
    PCLinuxOS-liveUSB Creator
    This is an explanation of what one should expect from this utility which is available from the PCLinuxOS repository and mirrors. This refers to version 0.8 (or greater) which should be in the repository very soon.
    This is a PCLinuxOS utility only and is not designed to work with any other OS or ISO of a different distro.
    It can be run from a ‘live’ session, either CD/DVD or USB device, or from an installed version of PCLinuxOS.
    It installs only on removable media.
    http://linux.softped...xOS-22543.shtml
    However, one should not think that PCLinuxOS is a KDE-only distribution, as it is distributed into several different editions with other desktop environments. The GNOME, MATE, LXDE, Xfce, Openbox, and Enlightenment (E17) editions are also very popular among the PCLinuxOS community. All of them support both 32-bit and 64-bit architectures.
    http://www.pendrivel...uxos-minimezip/
    Note: This is a very old (but popular) version of Minime!
    Essentials for creating a Portable PCLinuxOS MiniMe:
    • A 512MB or larger USB flash drive
    • pclinuxos*.iso
    • Universal USB Installer
    Well if all else fails then there is Easy2Boot
    http://forums.scotsn...83&hl=easy2boot
    Also once you have the tool set up on your usb adding or changing from an older version is pretty darn easy too. Add in the fact that you have the ability to add persistence to the relevant os's,  and you have a very easy way to show folks just what they have been missing. Did I mention it is free !
    Have fun  :breakfast:
    Install ARCH
    #12 OFFLINE   securitybreach
    • 23,647 posts
    Posted 11 September 2016 - 08:34 AM
    No love for the tried and true dd ?
    # dd bs=4M if=/path/to/linux.iso of=/dev/sdx status=progress && sync
    Replace sdx with the drive letter, not the partition. Example sdg not sdg1
    Example:
    # dd bs=4M if=~/Downloads/archlinux.iso of=/dev/sdg status=progress && sync
    #13 OFFLINE   wa4chq
    wa4chq
      Message Mogul
    • PipPipPipPipPip
    • 439 posts
    Posted 11 September 2016 - 01:40 PM
    Abarbarian....tnx for the info with links.  I will have a look at it.
    Securitybreach, that's what I used for the 64bit, worked fine....but I couldn't get to work for the 32bit community versions.  Found another 32bit version and that would not boot either.  Tried using Unetbootin...no luck.  I ended going with Porteus which does does what I want.
    thanks for the info and suggestions, you guys....
    #14 OFFLINE   wa4chq
    wa4chq
      Message Mogul
    • PipPipPipPipPip
    • 439 posts
    Posted 11 September 2016 - 02:04 PM
    Eric, it's a Dell Latitude D620.  It came preloaded with Mint.  I deleted it, partitioned the hard drive and added XP so I could do some flight sims (which I really haven't messed with since doing it...  :)  )  and put Mint back on.
    #15 OFFLINE   abarbarian
    • 5,553 posts
    Posted 11 September 2016 - 03:37 PM
    We have a Porteus thread here at Scot's
    http://forums.scotsn...9230&hl=porteus
    mind you it is quite a while since anyone posted in it. :breakfast:
    Install ARCH
    #16 OFFLINE   wa4chq
    wa4chq
      Message Mogul
    • PipPipPipPipPip
    • 439 posts
    Posted 11 September 2016 - 04:37 PM
    Thanks Abarbarian..... I'll look at it.  I've used it before but only on a flash drive.  I may just leave Mint on the lappy since I'm mainly interested in using it for movies.  All I have to do is boot the flash drive and I'm good to go....  Porteus has gmplayer instead of VLC but it wouldn't be hard adding the vlc to porteus.
    #17 OFFLINE   V.T. Eric Layton
      Nocturnal Slacker
    • 21,379 posts
    Posted 11 September 2016 - 07:53 PM
    Neil,
    That machine came with the same processor as my Dell Latitude 1521 (the one Josh gave me). It's an Intel Core2 Duo. It is most definitely a 64bit processor. :)
    http://www.intel.com...cifications.htm
    #18 OFFLINE   wa4chq
    wa4chq
      Message Mogul
    • PipPipPipPipPip
    • 439 posts
    Posted 12 September 2016 - 10:08 AM
    Hey Eric.....
    OK, I didn't know that.  This afternoon I'll give the pclinux64 live a try....
    thanks!
    #19 OFFLINE   Hedon James
    Hedon James
      Topic Cop
    • 818 posts
    Posted 12 September 2016 - 03:53 PM
    Not that I don't trust VT, but I'd verify before spending a whole lot of time downloading/booting, etc...  Verify by typing in terminal
    lscpu
    If it's not obvious after that, follow post #7 above...
    #20 OFFLINE   securitybreach
    • 23,647 posts
    Posted 12 September 2016 - 05:05 PM
    lscpu
    Agreed :thumbsup:
    #21 OFFLINE   V.T. Eric Layton
      Nocturnal Slacker
    • 21,379 posts
    Posted 12 September 2016 - 07:54 PM
    Ah... you guys saw that post on G+ today too, huh? The one about the usefulness of the ls command. ;)
    Oh, and I got the info about the processor in that lappy from Dell, and the specs on the CPU from Intel. If you can't trust them, who can you trust? Microsoft? ;)
    #22 OFFLINE   securitybreach
    • 23,647 posts
    Posted 12 September 2016 - 08:08 PM
    I didn't see the ls rant and I just rechecked too...
    #23 OFFLINE   V.T. Eric Layton
      Nocturnal Slacker
    • 21,379 posts
    Posted 12 September 2016 - 10:48 PM
    I can't remember who posted that on G+ today... TechBytes? No... it was... umm... AHA! Found it. It was Nixcraft
    --> https://plus.google....sts/aZwPeurhnJR
    And the actual webpage --> http://www.cyberciti...mands-examples/
    #24 OFFLINE   securitybreach
    • 23,647 posts
    Posted 13 September 2016 - 05:54 AM
    Oh I thought you meant that you posted it...
    #25 OFFLINE   Hedon James
    Hedon James
      Topic Cop
    • 818 posts
    Posted 13 September 2016 - 07:42 AM
    BWAHAHAHA!  LMAO!   :hysterical:
    Edited by Hedon James, 13 September 2016 - 11:46 AM.
